Throttle Bracket Fab for Venom Manifold (under the manifold???)
Bought a Venom manifold a while back from a member and Im trying to understand how Im going to get a throttle cable to work with these straight fatty runners.
In my mind I can only think of two options, Ill show you the pics first, think of what I should do, then read my ways and tell me whats up
Actually I wont even post my ideas, but they incorporated the cable going under the manifold because thats definetely the only way I can see it working, but I dont know
1- to put it under the manifold right away before the forth runner
2- to run it like stock and than somehow dip it straight down inbetween the 1-2 runners and then under #1 runner to the t/b
I dunno how those would work or what i could make to use the stock throttle cable that would work
Need some help
Need some help
if your afraid of the setup not allowing full throttle...then just remove the throttle linkage from the butterfly and position it in relation to the cable mount...something like 180 degrees. people with ITB's re-adjust the linkage to the butterfly all the time. pm if you dont understand.
from what I understand your problem is that the location you have to mount the throttle cable stop only alows for a limited amount of throttle. so you want to run the cable underneath the runners to allow full throttle range. your not the only person that has had this problem with the stock throttle body configuration with the venom intake manifold. all you need to do is remove throttle linkage (the puck) that connects the cable to the throttle plate. then position it in a manner that will alow full throttle from your mounting point. normaly it is about 180 degrees from stock if you mount the linkage stop on the top of the manifold.
B18C5-EH2
Apr 12, 2005 02:32 PM
W O T
Jan 29, 2005 06:22 PM
