Trailing arm bushing question.. found no threads asking THIS:
Old Jan 28, 2005 | 03:10 PM
kaj's Avatar
kaj
Default Trailing arm bushing question.. found no threads asking THIS:
okay, so THIS model uses the same bushing at THAT model, blah, blah. but! is the RIGHT side bushing the same as the LEFT side???
Old Jan 28, 2005 | 03:14 PM
ZygSpeed's Avatar
Default Re: Trailing arm bushing question.. found no threads asking THIS: (kaj)
Have you checked the part numbers?
My guess is that they WOULD be the same.
Old Jan 28, 2005 | 04:12 PM
jdmvtec28's Avatar
Default Re: Trailing arm bushing question.. found no threads asking THIS: (zygspeed)
I don't think there is a part number for the trailing arm bushing, I say this because you cannot replace just the bushing from Acura. They make you purchase a whole new trailing arm.
Old Jan 28, 2005 | 10:36 PM
db8sirg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaj &raquo;</TD></TR><TR><TD CLASS="quote">okay, so THIS model uses the same bushing at THAT model, blah, blah. but! is the RIGHT side bushing the same as the LEFT side???
same for both sides.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think there is a part number for the trailing arm bushing, I say this because you cannot replace just the bushing from Acura. They make you purchase a whole new trailing arm.</TD></TR></TABLE>
there is a service bulletin with a part number for the tr bushing.
52385-SR3-000
Old Jan 29, 2005 | 02:46 AM
jdmvtec28's Avatar
Default Re: Trailing arm bushing question.. found no threads asking THIS: (db8sirg)
no *&%$, ignorance was bliss, my bad.
Old Jan 29, 2005 | 12:06 PM
kaj's Avatar
kaj
bad ***, i appreciate it. thanks.
Old Jan 29, 2005 | 12:09 PM
kaj's Avatar
kaj
last question, that i KNOW has been asked.. but i can't find it via search either:
is the ITR and civic bushings the same? i'm wondering if ITR uses a different durometer bushing? if so, i should probably just go with Engergys??
Old Jan 29, 2005 | 12:17 PM
mingbling96's Avatar
Default Re: (kaj)
just get OEM. They are the same.
Old Jan 29, 2005 | 01:24 PM
kaj's Avatar
kaj
Default Re: (mingbling96)
that's what i was hoping to hear. i don't really need the added performance of polyurethane.... and i don't wanna hear them start to squeak, so i'll go OEM
Old Jan 29, 2005 | 02:32 PM
B2FiNiTY's Avatar
Default Re: (kaj)
Get mugen
Old Jan 29, 2005 | 02:50 PM
defy's Avatar
just make sure u put it in the right way, has a lil that points "up" or "down" cant remember
Old Jan 30, 2005 | 10:23 AM
kaj's Avatar
kaj
Default Re: (defy)
thanks for the tip
i wonder if there's a way i can get this covered under warranty....
dbailey
11
Jan 15, 2007 06:41 PM
OMG WTF
Suspension & Brakes
Jul 20, 2006 07:49 PM
vtec25
Aug 29, 2005 05:22 PM
RAB
32
Dec 20, 2004 03:16 PM
Red Ride
Apr 21, 2003 08:50 AM
