Where to Get ODB1 Harness
Old Jan 14, 2002 | 08:39 AM
azn98R's Avatar
Default Where to Get ODB1 Harness
I am getting an OBD1 Civic EX ecu so I can hook it up to an hondata. But I need an harness for the OBD1 ecu. You guys know where I can get one for a good price or ever dirt cheap... hehehe.
let me know cause that all I need to finish my mods.
Thanks,
Old Jan 14, 2002 | 08:42 AM
adam's Avatar
Default Re: Where to Get ODB1 Harness (azn98R)
hondata sells them.. maybe try one of the dealers from FL on their website
Old Jan 14, 2002 | 08:45 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
very few people actually make them. I'm using one of kenji's harnesses.
email him at kenji211@gte.net for more info.
HX_Guy's Avatar
Default Re: Where to Get ODB1 Harness (Dave-ROR)
Make your own..I did
Old Jan 14, 2002 | 08:53 AM
azn98R's Avatar
Well, the dealer is charging $300 for the harness and I feel that's a lil too much for a harness. I am going to check with Kenji.
Sounds interesting, how....
b00st-0wnz's Avatar
Default Re: Where to Get ODB1 Harness (HX_Guy)
That's true, you can do that. HX saved ~75 bucks that way (IIRC?). It's worth the 75 extra imo though. I'm kinda weary of fuggen around with ecu wiring.. dunno why.
Old Jan 14, 2002 | 08:59 AM
HX_Guy's Avatar
It cost me $50 to make my own harness...vs buying one for $250...so I saved $200 ...plus gained the know-how of making one.
You need an ECU plug for the year of your car and the harness plugs from a OBDI car. Here is the ECU plug Im refering to...
The end product will look like this...
azn98R's Avatar
I just IM kenji, but not sure if it's the right one . There are three of them...
Old Jan 14, 2002 | 09:01 AM
HX_Guy's Avatar
Also..I have the ECU pinouts for the OBDI plugs, and assuming you have a '98 Type R..I also have those pinouts
Its just a thing of matching up the pins and soldering
Old Jan 14, 2002 | 09:03 AM
azn98R's Avatar
Wow, looks deep.... dunno if I wanna do that myself. maybe I should pay you to make me one . I mean it works fine right?
00ITR #543's Avatar
How long did it take you to do that??????
Old Jan 14, 2002 | 09:05 AM
HX_Guy's Avatar
Default Re: Where to Get ODB1 Harness (00ITR #543)
Never had one problem with mine..worked the first time I plugged it in, no codes or anything.
Took about 3-4 hours of figuring it out, double and trippe shecking connections and shrink wrapping the connections. Yea..pretty time consuming...but hey, whats $200 worth to ya?
azn98R's Avatar
[QUOTE]Also..I have the ECU pinouts for the OBDI plugs, and assuming you have a '98 Type R..I also have those pinouts
I do have a '98 type-r.... hehe hook it up
Old Jan 14, 2002 | 09:09 AM
b00st-0wnz's Avatar
IIRC, in your original post, that one connector cost $50 (from another ECU). Are we not including wires, the 3 other plugs, soldering gun/iron, solder, heat shrink, solder sucker, etc into the price these days?
Old Jan 14, 2002 | 09:12 AM
HX_Guy's Avatar
Oops..sorry. I already had a soldering gun and solder, got the shrink wrap for free and I hacked my stock HX ECU to get the OBDII plug. The only thing I bought was the OBDI plugs for $50 (all 3).
Old Jan 14, 2002 | 09:13 AM
HX_Guy's Avatar
Here are the pin outs for a 96-98 OBDII ECU to OBDI
OBDII Connector D
1 TPS = D11
2 ECT = D13
3 MAP = D17
4 VCC1 = D19
5 BKSW = D2
7 PHO2S = D14
8 IAT = D15
10 VCC2 = D20
11 SG2 = D22
12 SG1 = D21
13 SHO2/SG = NA
14 SHO2S = NA
16 EL = D10
OBDII Connector C
1 CKFP = NA
2 CKPP = B15
3 TDCP = B13
4 CYPP = B11
5 ACS = B5
6 STS = B9
7 SCS = D4
8 K-LINE
10 VBU = D1
11 CKFM = NA
12 CKPM = B16
13 TDCM = B14
14 CYPM = B12
15 VTEC PRS = D6
16 PSP SW = B8
7 ALTF = D9
18 VSS = B10
OBDII Connector A
1 INJ4 = A2
2 INJ3 = A5
3 INJ2 = A3
4 INJ1 = A1
5 SO2S HTC = NA
6 PO2S HTC = A6
8 VTEC SOL =A4
9 LG1 = A26
10 PG1 = A23
11 IGP1 = A25
12 IACV = A9
15 PCS = A20
16 FLR = A7
17 ACC = A15
18 MIL = A13
19 ALTC = A16
20 ICM = A21
22 LG2 = B2
23 PG2 = A24
24 IGP2 = B1
27 FANC = A12
Old Jan 14, 2002 | 09:22 AM
TypeR0149's Avatar
Did you write down what plugs go where, like a cheat copy, if so could you mail it to me
Old Jan 14, 2002 | 09:29 AM
HX_Guy's Avatar
Default Re: Where to Get ODB1 Harness (Vegeta)
Yea...look at the post above yours
Old Jan 14, 2002 | 09:32 AM
TypeR0149's Avatar
sorry i started writing my post before that was posted, then got distracted at work, sorry
Old Jan 14, 2002 | 09:37 AM
b00st-0wnz's Avatar
Yikes, you didn't use a solder sucker? If you were to do this yourself and didn't have the parts, I'd guesstimate that you were looking at 150ish.. 50 for the 3 small plugs, whatever the big one cost (I've heard close to 50 as well for that one), soldering gun/iron, bunch of wires, the pin connector things, solder sucker, heat shrink, etc. Also some of that epoxy crap would be nice on the big connector backside to cover up/protect the pins mor than heat shrink.
Old Jan 14, 2002 | 09:42 AM
HX_Guy's Avatar
No, I took aprt the OBDII ECU and used a dremel to detach the plug from the pc board...look at the picture in the earlier post. No extra wires are (usually) needed, because the OBDI plugs come with several inches of wire attached to them.
If youre a do-it-yourselfes then I think its worth it...if not, just dish out the cash
...but if there a problem (and there are problems sometimes even with ones you buy pre-made)...it'll be harder to trouble shoot since you werent the one who assembled it.
Old Jan 14, 2002 | 09:45 AM
b00st-0wnz's Avatar
Ah, didn't know that
Anyways, after using a harness, I think I'd replace or extend the wires anyways to bring the wires to above the ecu. with no interior (in my case) some of those wires like to stick out with the normal harness length.. I just need to move them I guess.
Old Jan 14, 2002 | 11:15 AM
ezark's Avatar
http://www.prospeed-performance.com
VERY clean harnesses.
Old Jan 14, 2002 | 11:55 AM
azn98R's Avatar
Default Re: Where to Get ODB1 Harness (krazE)
How recomendable are these guys at prospeed-performance. They also sell Hondata... If anything I will get everything there. Have any of you done business with Prospeed?
Old Jan 14, 2002 | 12:04 PM
C-speed's Avatar
We also carry the OBD2 to OBDI1 harnesses:
http://www.c-speedracing.com/onlines...a.html#pricing
