HELP NEEDED: steps in replacing complete airbag set up ! 96+
ok so im doin a complete airbag swap in my gf's car . i got the bags and a clockspring and a module. .
now i got the new bags in place and plugged in,
Question #1: i reused the same clockspring, is that ok? they dont go bad when the bags pop right?
Question#2 where is the sensor located in the front that i need to replace? i didnt recieve one with my set of bags so i need one because im sure u cant reuse it can u?
Question #3 if i reconnect the battery with the bad module and sensor from the old set up will the new bags deploy?( this would be a nightmare!)
Question #4 where is the module locateD?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltRaH22 »</TD></TR><TR><TD CLASS="quote">Question #1: i reused the same clockspring, is that ok? they dont go bad when the bags pop right?
WTF is a clockspring???
It's in the SRS control unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltRaH22 »</TD></TR><TR><TD CLASS="quote">Question #3 if i reconnect the battery with the bad module and sensor from the old set up will the new bags deploy?( this would be a nightmare!)
Probably not, but I wouldn't risk it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltRaH22 »</TD></TR><TR><TD CLASS="quote">Question #4 where is the module locateD? </TD></TR></TABLE>
Under the center of the dash by the firewall.
clockspring is that circle piece under the airbag with the 3 plugs on it. . i think thats what its called right?
so the module and the "sensor" are one in the same or 2 different things
also is the module easy to get to? u said in behind the dash? sounds like a project.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltRaH22 »</TD></TR><TR><TD CLASS="quote">clockspring is that circle piece under the airbag with the 3 plugs on it. . i think thats what its called right?
I call that a cable reel.
The impact sensor is inside it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltRaH22 »</TD></TR><TR><TD CLASS="quote">also is the module easy to get to? u said in behind the dash? sounds like a project.</TD></TR></TABLE>
No, I said it's under the dash. Easy to get to. Under the 2 black covers.
ok so thats not bad, i just need to replace the sensor/module and im all set. . why is it no matter how safe u are with airbags u always gotta fling when plugging them in and connecting the power back up? they make me nervous
