how did you disconnect the hose from the PCV valve?
Old Jan 14, 2002 | 08:24 AM
citanest's Avatar
New User
Default how did you disconnect the hose from the PCV valve?
I was try to disconnect the hose and found there isn't any clamp fastening the hose onto the PCV valve at the manifold. So, should I just force it out? any trick to disconnect that hose? Also, it's a pain to get access to that hose as it's underneatht the manifold. Please give me some advices.
Old Jan 14, 2002 | 08:36 AM
R134's Avatar
Default Re: how did you disconnect the hose from the PCV valve? (citanest)
Just pull the pcv out of the manifold, it just pops off, then you can take off the hose easily.
Old Jan 14, 2002 | 10:26 PM
citanest's Avatar
New User
Default Re: how did you disconnect the hose from the PCV valve? (R134)
I pulled the pcv but still can't pull the hose as it's underneath the manifold. I just see the hole which the PCV used to connect to and the hose is on the other side. I tried to pull the hole with a small clamp, but didn't succeed. Any other trick?
I tried different angle and direction and can't get access to the hose underneath. anyone?
thanks
metalslug
Dec 22, 2015 04:47 PM
rick_rabies
Apr 6, 2009 12:04 PM
Enta
Jan 29, 2007 03:51 AM
houstondigital
Aug 29, 2005 11:48 AM
JerseySiPOS
12
May 16, 2004 10:40 AM
