wiring haransse
I don't understand. You have Dynamic's name in your signature.
Won't they build it for you?
If not go see Mike there in Carlise. He did one already for Stricklin's car.
You can do it yourself like I did.
Lay the HF harness over your engine and extend the wires that won't reach and add the wires that aren't there. I had to add IAB for the GSR manifold, add Vtec and oil pressure, knock, 4 wire O2. Lengthen the MAP wires, lengthen the emissions purge wires, fan switch wires, etc. Change the plugs on the injectors to OBD1. Wire the resistor plug wires all together. It sounds hard but you could do it in a couple of hours. Get a GSR engine harness so you can rob plugs off of it.
Pick up a harness converter to change your ECU plugs from OBD0 to OBD1. Also if you are gonna have two harnesses. The one on your car now and the one you plan to use with the GSR, make sure you get an HF harness from the year that matches your car. 88HF get 88HF harness, 89HF get 89HF harness, 90HF and 91HF can use 90HF or 91HF harness since they are the same. Some bastard on here told me they were all the same(88-91). They aren't. Also don't let someone tell you an CRX Si harness will fit. It won't.
I am adding electric speedo from an SIR and converting it to MPH so it will read to 180mph, otherwise you will need a DA speedo sender or a longer speedo cable.
Run one of these: Click me
Use the GSR distributor, ecu and 4 wire o2 sensor. Comes with detailed instructions for an easy install that you can do by yourself.
JAson
http://www.JKobdconversionharness.com
JAson
skarpenz
May 11, 2010 09:38 AM
GSR eg94
Mar 15, 2009 09:05 PM
