Welding The Engine Block
Old Jan 28, 2005 | 11:40 AM
VTEC Sol's Avatar
Default Welding The Engine Block
I was just trying to get some input on welding the block, anybody recommend it, anyone not recommend it???
Old Jan 28, 2005 | 12:01 PM
Engloid's Avatar
OG Fabricator
Default Re: Welding The Engine Block (VTEC Sol)
Why would you want to weld it?
Old Jan 28, 2005 | 07:26 PM
RMF
Guest
Posts: n/a
You can weld on the block all you want .As long the main webs are not cracked.If you window the block ,Like the back side of # 4.Just make sure that the crack doesn't go up into the main webs.If it does ,Give it to the aluminum guy when comes by.I would tell you how to weld it.But I don't think it would matter. D C straight ,Straight helium.
Ef3..saloon
Engine Machining & Assembly
Aug 20, 2015 04:14 AM
fastboy559
Nov 3, 2007 06:00 PM
x91crxsix
Jul 28, 2006 10:42 AM
Slimm-rw-
Apr 6, 2004 01:50 PM
Nextelbuddy
Feb 10, 2004 09:23 AM
