pedal support removal 90 civic
I got to replace the pedal support or bracket on a 90 civic because it is craqued, I lowered the steering column and removed all the bolt, but the pedals just don't want to come loose. Shoul I removed the brake booster and master cylinder as well? I disconnected the brake switch and clutch pedal switch, but it's still tight any ideas orbolt i'm missing?
got it all back together now, I had to lower the steering column, remove all the air ducts, I learned a lot today
The was a bolt behind the air ducts.
I am an experienced mechanic And That was a big ***** job
The was a bolt behind the air ducts. I am an experienced mechanic And That was a big ***** job
I did it over my Christmas break since I cracked my clutch pedal support, took me about 90 minutes to remove pedals from chassis, 60 from donor car, and about 210 to put it back together.
Fuster_Cluck
Mar 27, 2007 05:28 PM
Khmi
Jun 21, 2004 02:10 PM
