cross-member clearance question?? sms-profab header??
Old Jan 28, 2005 | 10:46 AM
jdmEFsedan's Avatar
Default cross-member clearance question?? sms-profab header??
Has anyone had problems with the sms header hitting an EF cross-member?? I'm on a budget and don't have money to change the cross-member at this time.
My proposed set up will be:
B18C block
SMS header
etc.
Thanks H-T members!!
Old Jan 28, 2005 | 10:54 AM
dr_latino999's Avatar
Default Re: cross-member clearance question?? sms-profab header?? (EF_VTEC)
It is a 4-2-1 design (Roughly speaking), correct?
Old Jan 28, 2005 | 11:22 AM
Karterguy13's Avatar
Default Re: cross-member clearance question?? sms-profab header?? (dr_latino999)
notch the support
Old Jan 28, 2005 | 12:05 PM
jdmEFsedan's Avatar
Default Re: cross-member clearance question?? sms-profab header?? (Karterguy13)
I believe it is a 4-2-1 design with a 2.5 inch collector.
Is it really necessary to notch the cross-member? Anyone have any pics of this?
Thanks again H-T
Old Jan 28, 2005 | 04:58 PM
Fred n J_v2.0's Avatar
Yes, if you plan to use the stock crossmember, you will have to notch a big chunk of it out. It also depends on how much clearance the header will need, as some headers have different designs than others.
Here is a pic I found from searching of a stock crossmember notched:
Old Jan 28, 2005 | 07:20 PM
jdmEFsedan's Avatar
Default Re: cross-member clearance question?? sms-profab header?? (Fred n J's_1.8's)
wow...that thing looks mangled. not too pretty if ya ask me. anyone else???
Old Jan 28, 2005 | 08:09 PM
Thats about how all the ones I have seen look
Old Jan 28, 2005 | 08:14 PM
mrspeaker's Avatar
Just bang the metal lip with a big hammer..
Old Jan 29, 2005 | 04:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">wow...that thing looks mangled. not too pretty if ya ask me. anyone else???</TD></TR></TABLE>
That's pretty much your only choice if you want to keep the stock crossmember. The cheapest crossmember out there is the place-racing, which should allow clearance for whatever header you are thinking about getting.
Other than that, your pretty much limited by the amount of money you want to spend.
Old Jan 29, 2005 | 03:05 PM
fekyoride's Avatar
Buy a traction kit, L con is the way to go. I installed a 98 type r header with a b16 swap in my buddy's 91 hatch and we had to cut the crossmember to crap. Buy a traction kit. It's lighter, stronger, has great clearance, eliminates wheel hop, and is cosmeticly pleasing. we actually beand the first crossmember we tried to modify and had to use on i had laying around. L con traction kits are the way to go.
Old Jan 29, 2005 | 05:44 PM
Default Re: cross-member clearance question?? sms-profab header?? (brokeyouoff)
On a 91 civic do traction bars make a diff? I don't get any wheel hop now.
Old Jan 30, 2005 | 08:24 AM
jdmEFsedan's Avatar
anyone have a site for L con???
Old Jan 30, 2005 | 09:10 AM
HamiltonRex's Avatar
Heres what a notched crossmember is supposed to look like, not that mangled garbage...
Mine
Old Jan 30, 2005 | 10:11 AM
Default Re: cross-member clearance question?? sms-profab header?? (HamiltonRex)
That looks good
Old Jan 30, 2005 | 10:33 AM
jdmEFsedan's Avatar
nice work!!
anyone modify a cross-member with a sms (or similar type) header?
pics anyone?
Big-ups to HT member for all the great input!!
Old Jan 30, 2005 | 01:14 PM
daidilus's Avatar
how much was the welding?
Old Jan 30, 2005 | 06:02 PM
Default Re: (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">how much was the welding? </TD></TR></TABLE>
probably about $2 in gas and $0.50 in wire. Plus a little bit of wear on a grinding wheel.
around $3
Old Jan 30, 2005 | 06:03 PM
Default Re: (HamiltonRex)
oh yeah... The header was a large 4-1 and its a b18c in crx with DIY mounts.. so it should clear 95% of headers.
Old Jan 30, 2005 | 07:47 PM
daidilus's Avatar
i need your help!!
donperry
Jun 16, 2015 04:48 PM
gerard92692
Oct 22, 2013 07:39 AM
SiR Inspired ED7
Aug 6, 2007 07:28 AM
91teg
Feb 17, 2003 11:06 PM
EG_93Civic
Feb 3, 2003 05:44 PM
