would this i/c be to big for the greddy sohc vtec turbo kit
Old Jan 28, 2005 | 08:01 AM
Gant's Avatar
Default would this i/c be to big for the greddy sohc vtec turbo kit
: Core: 30" wide X 5" tall X 2" deep End tanks are 5.5" tall X 3.25 deep 2.5" OD piping X 2.5" long This intercooler measures 33.75" from outside of end tank to outside of end tank
greddy sohc vtec kit boost at 5.5 out the box i plan to keep it 5.5 with the i/c
Old Jan 28, 2005 | 08:22 AM
PHOBIA's Avatar
jrc intercooler? it looks perfect to me.
Old Jan 28, 2005 | 08:32 AM
Gant's Avatar
Wat i mean is would it be to much of a pressure drop
with the greddy turbo kit? its only a 5.5 psi kit and a tdo5 turbo i belive
its a johnny race car i/c,
Old Jan 28, 2005 | 08:34 AM
PHOBIA's Avatar
no its perfect,its a small unit.its not like it's a supra intercooler or any thing.i amagine if you cut a dsm intercooler in half and set it side by side the jrc would be slightly longer.
Old Jan 28, 2005 | 08:39 AM
mrspeaker's Avatar
Default Re: (Ba4)
At only 5psi you would make more power with no intercooler or with something smaller..Like dsm sidemount,,
Although with that intercooler you'll always have room for improvement without having to buy another ..And its safe..
Old Jan 28, 2005 | 09:53 AM
4drEF's Avatar
Keyboard Humorist
Default Re: would this i/c be to big for the greddy sohc vtec turbo kit (Ba4)
Can you just turn up the boost if it drops too much?
Old Jan 28, 2005 | 10:20 AM
Rostr02's Avatar
Default Re: (mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">At only 5psi you would make more power with no intercooler or with something smaller..Like dsm sidemount,,
Although with that intercooler you'll always have room for improvement without having to buy another ..And its safe..</TD></TR></TABLE>
thats what i would say too just go get yourself a dsm side mount it would be less obvious too
Old Jan 28, 2005 | 10:48 AM
Gant's Avatar
Dsm side mounts do not fit they hang wayyyy to low,
turning up the boost probably would get rid of the lag but like i said i want to stay at the 5.5 psi the kit boost at
the reason im getting this i/c cuase its real cheap
its a johnny race car intercooler,
i dont know about running no i/c i was thinking of running no i/c but foudn this cheap intercooler
and heard they arent so bad.
should i just run no i/c?
Old Jan 28, 2005 | 10:54 AM
mrspeaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">should i just run no i/c?
Yes and no..
I say be safe and run one..
Old Jan 28, 2005 | 12:00 PM
KevronsEG's Avatar
Default Re: would this i/c be to big for the greddy sohc vtec turbo kit (mrspeaker)
i ran the JRC 5in on my crx with mini me tubro on 5psi and ran 14.0 with 102 trap, i had no tracion in 1,2 half or 3rd. just my .02
Old Jan 28, 2005 | 12:18 PM
nuckingfuts's Avatar
Default Re: would this i/c be to big for the greddy sohc vtec turbo kit (IAmTheRealKevron)
my dsm sidemount IC fits fine, i had to modify it however and remove the tow hook on passengerside.
Old Jan 28, 2005 | 12:21 PM
Gant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmTheRealKevron &raquo;</TD></TR><TR><TD CLASS="quote">i ran the JRC 5in on my crx with mini me tubro on 5psi and ran 14.0 with 102 trap, i had no tracion in 1,2 half or 3rd. just my .02</TD></TR></TABLE>
I c, im thinking of getting the 5inch and see how that goes, what size turbo are u using?
Old Jan 28, 2005 | 12:46 PM
KevronsEG's Avatar
i ran an
apexi turbo manifold/turbo/downpipe
2.25 exhaust with es oval muffler
2in from turbo to intercooler
2.5 from cooler to TB
uberdata
ported intake manifold 60mm TB
Old Jan 28, 2005 | 12:59 PM
Gant's Avatar
What size was ur turbo
Old Jan 28, 2005 | 01:09 PM
EJ1 wilcox's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">At only 5psi you would make more power with no intercooler or with something smaller..Like dsm sidemount...</TD></TR></TABLE>
I'm not too sure about that.... I would bet that you would see an increase with the JRC intercooler over the non-intercooled setup...
In theory you should be able to make more power even if the pressure drops a bit because the intake charge will be much colder...
A while ago I read a magazine article in which they dynod the stock Greddy kit and then added the Greddy FMIC, which has a much larger internal volume than the JRC, there was a slight drop in intake pressure but over a 15whp increase... more horsepower at lower boost with safer intake temps... sounds like a good investment to me
Old Jan 28, 2005 | 01:16 PM
KevronsEG's Avatar
Default Re: (Ba4)
its an apexi turbo, they say its same size as a 16g
turbo sol
Mar 9, 2004 08:48 AM
Troy
Oct 5, 2002 12:11 PM
BD7581
Jun 28, 2002 10:55 AM
tsjag17
Oct 26, 2001 06:08 PM
