h22 in a crx
Old Jan 14, 2002 | 06:46 AM
Turbo-Si's Avatar
Default h22 in a crx
Can a h22 fit in a crx????
Old Jan 14, 2002 | 06:50 AM
laughinxxx's Avatar
New User
Default Re: h22 in a crx (Ludesi)
Yes.
Old Jan 14, 2002 | 10:55 AM
H22Si's Avatar
It can be done deffinately. Ever see the L'Natural CRX? Also there is a girl in Birmingham Al, who has a CRX with an H22 turbocharged. I believe she runs somewhere in the area of 12's on street tires. Expect to spend quite a few dollars on custom parts, and weight distribution is biased a lot towards the front, even more so than the EG/H22 swap.
Old Jan 14, 2002 | 11:22 AM
JDM ZC REX's Avatar
Default Re: h22 in a crx (H22Si)
I agree with H22Si.... the weight is far greater than any other motor out there.... the H22 is one of the heaviest motors honda has come out with. It's got amazing power but it's really hard to make it streetable in a CRX.... the short wheel base makes for massive amounts of understeer unless you spend a fortune on front suspension and good tires. It's a straight line monster, but in the twisties you've sacrificed power for light weight. If you're looking for a good all around motor for the CRX the H22 is not it... go with something lighter like a b16 or even a b18. But you can't beat the H22 for power. Hope this helps.
Old Jan 14, 2002 | 11:26 PM
typeSwarrior's Avatar
Find yourself a copy of the Fall 2001 Honda Tuning magazine and you will find a 6 page article on a drag CRX with the H22a that runs a 10.68@129.8mph N/A!!!! Hope that answers your question
Old Jan 15, 2002 | 07:59 AM
Turbo-Si's Avatar
Default Re: h22 in a crx (typeSwarrior)
what about the h22 in hb will that be easier, less money?
Old Jan 15, 2002 | 08:22 AM
laughinxxx's Avatar
New User
Yes.
Old Jan 15, 2002 | 05:01 PM
crxman2's Avatar
New User
Where is this turbo h22a in the crx?? Where does the car run?? You understand there is no mount kit Available to install a h22 in a 88-91 chasis. Everything would be a custom fab on it. Although it is possible to achieve this i would like to see it first. As far as 12 on street tires in a rex with h22a turbo it better be low 12's on radials . I myself have a crx drag chasis me and couple of my freinds have been working on for quite sometime now. it is b series and turbo all fiberglass front ,fiberglass doors, lexan , ten point cage,sheet metal dash,As far as the 12's on radials my 1994 integra weighs 2650 with me in it and i run 13.0 at 111mph on drag radials. If this is a true statement then we would like to see the car run at track.
Old Jan 15, 2002 | 05:05 PM
JG Luder's Avatar
Default Re: h22 in a crx (crxman2)
Bham? Hmmm... never seen or heard of this.
And the H22A is only 80 lbs or so heavier. It's just a ricer myth that they weigh the car down to the point of stupid handling. The only thing you might have trouble with is suspension and room to work.
Old Jan 15, 2002 | 06:26 PM
BoM's Avatar
BoM
Default Re: h22 in a crx (JG Luder)
very true....never believe anyone unless they've driven one before...i've driven my friends 89 hatch H22 and thats similiar to a CRX and the handling isn't bad, its not like a normal civic or integra.
But thats because my friends hatch is still on stock suspension and on 17's
Old Jan 20, 2002 | 11:19 PM
CleanCL's Avatar
man, go with a b16a2 you will be more happy with that like everyone else has said it ways alot but if you have your mind set on a h22a then go with the type S 220hp
Old Jan 21, 2002 | 12:24 AM
blackANESE's Avatar
Default Re: h22 in a crx (CleanCL)
I heard that the oil pan hangs really low with the H22 in a crx swap. Maybe the mount kits they have now change this, but I know before you couldn't have a substantially lowered crx with the H22 in there. Anyone else heard of this problem before?
Old Jan 21, 2002 | 03:51 PM
H22Si's Avatar
Yes it is low 12's on street radials, it isn't a drag car, it's some 17-18 year old girls daily driver that I guess daddy paid for. I saw her run a '94 RX7 on the freeway and she pretty much blistered his ***! haha. I never talked to her personally but from the looks of it it's simply a fast *** freeway car.
ketchup
Mar 31, 2008 04:12 PM
ekkkk20
34
Mar 26, 2008 10:13 AM
540i6
Jan 8, 2005 06:40 PM
hondapwr
48
Aug 25, 2003 11:29 AM
