throwing code 22?
Old Jan 27, 2005 | 11:21 PM
egg_baLLa's Avatar
Default throwing code 22?
i just put in my friends 94 gsr ecu into my 93 hb which has a 96 b18c swap. when i put in his ecu, code 22 came up which is the vtec pressure valve. i've read that it could be low oil pressure, however, a couple hours prior to putting in the ecu, i changed my oil.
i've also read something about oil pressure switch or something, but what is that and where is it located?
can anyone else pinpoint the problem and how i can fix it?
Old Jan 27, 2005 | 11:34 PM
egg_baLLa's Avatar
Default Re: throwing code 22? (egg_baLLa)
ok heres what i found and i really think this might work.
https://honda-tech.com/zerothread?id=869811
however im still unclear and how to connect A4 to D6?
Old Jan 27, 2005 | 11:38 PM
CA6VTEC's Avatar
<FONT COLOR="royalblue"> Did you even bother to check to see if do have the Oil Pressure Sensor, before you jump to conclusion. Which ecu were you using before? Which Harness are u using now? OBD2?</FONT>
Old Jan 27, 2005 | 11:40 PM
egg_baLLa's Avatar
Default Re: (CA6VTEC)
no i dont think i have it because ive just read that jdm and edm models 96+ dont have the oil pressure sensor. i was using my chipped p28 before and am using the obd1 harness.
so im guessing i have to splice D6 to A4 but i have no idea how to do this.
can someone post up a pic of the pin layout?
Old Jan 27, 2005 | 11:49 PM
egg_baLLa's Avatar
Default Re: (egg_baLLa)
yeah i checked. i dont have that green thing that comes out from the vtec solenoid.
bump cuz i have state ref tomorrow.
someone please help.
Old Jan 27, 2005 | 11:50 PM
CA6VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg_baLLa &raquo;</TD></TR><TR><TD CLASS="quote">no i dont think i have it because ive just read that jdm and edm models 96+ dont have the oil pressure sensor. i was using my chipped p28 before and am using the obd1 harness.
can someone post up a pic of the pin layout?</TD></TR></TABLE>
<FONT COLOR="royalblue"> Open your hood & check. It's a Big Green Plug. Before you go do any splicing. If you don't have the sensor, that means u have a plug hanging somewhere, just get the sensor and put it on.
https://honda-tech.com/zerothread?id=478377
</FONT>
Modified by CA6VTEC at 4:52 AM 1/28/2005
Old Jan 27, 2005 | 11:58 PM
egg_baLLa's Avatar
yeah i do see that green plug. its just hanging and no where to go.
theres no way i can get the sensor now cuz i have my state ref appt in a few hours. i just need the pinout pic and how to connect them.
Old Jan 28, 2005 | 01:20 AM
egg_baLLa's Avatar
ttt anyone?
Old Jan 28, 2005 | 01:27 AM
CA6VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egg_baLLa &raquo;</TD></TR><TR><TD CLASS="quote">ttt anyone?</TD></TR></TABLE>
Old Jan 28, 2005 | 01:37 AM
egg_baLLa's Avatar
i've aleady found that thread. but thanks though.
also one more question: do u just twist on the oil pressure switch?
im trying to borrow my friend's oil pressure switch and i was wondering if i could just twist his off and put it on mine.
Travis R
Jul 23, 2011 02:06 PM
EF8IGHT
Jan 13, 2006 05:37 AM
Slvr_CRX
Apr 6, 2004 07:11 PM
