koni yellows in the front and illumina's in the rear?
would there be any problems with that set up? i want to lower my front more because i have springs and im short on cash so i was wondering if having koni yellows in the front and my illumina's that i have on right now in the rear would be fine? thanks
well since i can adjust the stiffness with the illumina's i figure it will still be a nice comfy ride
my friend's running on that set up now...no problem...since both are adjustable. you can adjusts it to what you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_to_the_MAX »</TD></TR><TR><TD CLASS="quote">would there be any problems with that set up? i want to lower my front more because i have springs and im short on cash so i was wondering if having koni yellows in the front and my illumina's that i have on right now in the rear would be fine? thanks</TD></TR></TABLE>
why does your shock matter to ride height?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeaAddict »</TD></TR><TR><TD CLASS="quote">
why does your shock matter to ride height?</TD></TR></TABLE>
from what i have read on former posts, you can perch the shock and that will lower your car more if you have springs. am i wrong?
anymore imput would be great thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_to_the_MAX »</TD></TR><TR><TD CLASS="quote">from what i have read on former posts, you can perch the shock and that will lower your car more if you have springs. am i wrong?
anymore imput would be great thanks</TD></TR></TABLE>
didn't know that...
i have illuminas. set to 3, 5 is waaay to rough.
didn't know that...
didn't know that...
i have illuminas. set to 3, 5 is waaay to rough.</TD></TR></TABLE>
i didnt know either til like 2 weeks ago..i got my illumina's set to 4, its rough but i like it that way
didn't know that...
with the perch adjustment, does anyone know how much lower i can lower my front? im trying to get rid of a 2 finger gap. would these be able to drop my sportlines 2 finger gaps?
should be one smooth ride, the koni shocks always drop your car a little lower than tokico. i used to have tokico blues and switched to koni reds and it dropped my car a little more. konis are the shiet!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_to_the_MAX »</TD></TR><TR><TD CLASS="quote">would the 3 perch get rid of my 2 finger wheel gap or should i go with the 5 perch?</TD></TR></TABLE>
bump
bump
