JDM type-R engine with GSR pistons?
Old Jan 14, 2002 | 05:47 AM
austrian type-R's Avatar
Default JDM type-R engine with GSR pistons?
HI guys.
I´ve a JDM spec engine with the 11.1:1 compression. What happens when I install a set of GSR pistons. HOw much would the cr lower. The GSR does have 10.1:1 and the combustion camber of the ITR is a bit higher. Where would my cr in fact be?
Thanks!
Old Jan 14, 2002 | 05:50 AM
Mike K's Avatar
Default Re: JDM type-R engine with GSR pistons? (austrian ITR)
If they are US GSR pistons, you'll be around 9.6:1 or around there.
JDM GSR pistons and you'll be in the 10.1:1 area..
Old Jan 14, 2002 | 06:04 AM
Default Re: JDM type-R engine with GSR pistons? (Mike K)
Is the piston design the same. I mean the floor of the piston is the correct one for the valves.
austrian type-R
Jan 14, 2002 09:05 AM
