d16
Old Jan 27, 2005 | 09:26 PM
v-6 hatch's Avatar
Default d16
what is the bore on a d-16. thanks guys
Old Jan 27, 2005 | 09:32 PM
robtec's Avatar
75mm
Old Feb 21, 2005 | 06:15 PM
GoneToTheDarkSide's Avatar
Default Re: (robtec)
Old Feb 21, 2005 | 06:53 PM
_BEN_'s Avatar
Concur.
Some nice reading if you are still curious about the D specs.
https://honda-tech.com/zero...age=1
Old Feb 21, 2005 | 10:51 PM
v-6 hatch's Avatar
Default Re: (_BEN_)
na i am good i am buildin my d16 right now for all motor 155 ho target
Old Feb 22, 2005 | 08:21 AM
civic-4-ges's Avatar
Default Re: (v-6 hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-6 hatch &raquo;</TD></TR><TR><TD CLASS="quote">na i am good i am buildin my d16 right now for all motor 155 ho target </TD></TR></TABLE>
What are you doing to get yourself there??
Old Feb 22, 2005 | 09:39 AM
joboost13's Avatar
Default Re: (civic-4-ges)
155 whp is a great goal What setup u plane on running wit?
Old Feb 24, 2005 | 01:47 PM
v-6 hatch's Avatar
Default Re: (joboost13)
with the single cam 155 hp goal i plan to do this as following ( i hope i can its tough but not to tough got love that challenge)
d16a6
i plan to run stnd bore zc piston' which should make 12.2 compresion on a stock head gaskit and head micro polished crnak acl bearings stock z6 rods with arp rod bolts
for the head here is where it gets fun
d16z-6 head
pnp 3 angle vavle job cb-r 929 custom itbs 270 injectors
stage 3 cat cam with an st-r cam gear
tranny just using a d15b with lsd
pulley i just ground down my crank pulley so its just the alt pulley it with out damging the harmonic balncer
its a pretty realsitic goal i think i should do high 13's in my eg which will be cool
p.s. sorry for my bad typing/spelling skils -
Old Feb 24, 2005 | 02:40 PM
Try 76MM bore ZC pistons
Old Feb 24, 2005 | 03:13 PM
v-6 hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Try 76MM bore ZC pistons </TD></TR></TABLE>
the compresion will be out the roof .... like 13.7 or some thingl like that huh?
Old Feb 28, 2005 | 06:45 PM
v-6 hatch's Avatar
what you guys think about my d-16 build huh huh?
Old Feb 28, 2005 | 07:47 PM
lohatch's Avatar
what fuel are you going to run it on?? what are you going to use for management?? what you running for intake and exhaust tracts??
Old Mar 1, 2005 | 02:32 AM
the compresion will be out the roof .... like 13.7 or some thingl like that huh?</TD></TR></TABLE>
12.5:1 with a thick headgasket
Old Mar 1, 2005 | 06:54 AM
v-6 hatch's Avatar
i'll be running it on 93 octane and tuning with chrome or ems
Old Mar 1, 2005 | 08:10 AM
I run 93 octane even on mine. Key is to tune
PM Builthatch, he has a TON of experience with this setup!
Old Mar 1, 2005 | 08:25 AM
TURBODEEZ's Avatar
Default Re: d16 (v-6 hatch)
75mm
NC_95_EJ
20
Nov 11, 2006 12:05 PM
h22acivicman
Sep 23, 2004 11:53 AM
lillthingz
Jul 26, 2004 11:55 AM
advance concepts
15
Jul 17, 2003 09:40 AM
KamikazeRacinz
Jun 12, 2003 09:22 AM
