b16a vs. b18cR
Old Jan 27, 2005 | 08:55 PM
b16a27's Avatar
Default b16a vs. b18cR
ok heres my situation i have a 92 teg with a b16a in it with jdmgsr trans with lsd ok i want to know by may 1st i need a running car i was thinking going with the R swap because it has more potenal or i could bulid the b16a to the max what should i do have a b18cR with intake header back exhaust or a bulit b16a what will be faster by may 1st i make about 800$ a month im olny 17 so money is a issue but i have a grand saved and a b16a to sell so any opinoins
Old Jan 27, 2005 | 09:34 PM
ProjectDarkBlack's Avatar
Default Re: b16a vs. b18cR (b16a27)
stick with the B16, it responds well enough to bolt-ons to justify keeping it, and if you need more down the road you can always ram air down its throa t
Old Jan 27, 2005 | 10:00 PM
Paulnsx's Avatar
i would agree with looking at FI before swapping in a b18c5... atleast that is my opinion. would be a whole lot cheaper/easier.
Old Jan 27, 2005 | 10:08 PM
pubestripe's Avatar
Default Re: b16a vs. b18cR (Paulnsx)
is it really worth it to spend 5g+ on a type r swap when that could go into the b16? i say keep the b16... much better option.
Old Jan 28, 2005 | 07:39 AM
TeaAddict's Avatar
800 a month is a lot if you have zero expenses...
Old Jan 28, 2005 | 07:44 AM
Greenery18's Avatar
Default Re: b16a vs. b18cR (TeaAddict)
Yea you already have a good engine to start with, or at least a good head. All you are really getting with the c5 block is oil squirters, and slightly higher displacement. An LS or B20 block would be much more cost effective, imo Not to mention you could go turbo with 5k easy..
Old Jan 28, 2005 | 07:53 AM
sleevedgsr's Avatar
I would go with the C1 instead!
jimmysbrother
Apr 5, 2016 11:48 PM
tallguy21
13
Feb 10, 2011 07:43 AM
b16a27
Jan 27, 2005 09:37 PM
