89 Civic DX gauge clusters
Old Jan 27, 2005 | 08:06 PM
EF Two.'s Avatar
Default 89 Civic DX gauge clusters
Which cluster works in the 88-89 Civic DX model? I've tried a few and none worked. I know the CRX cluster does not work. Does the 88-89 Civic SI cluster really work and can someone verify that. I got one but it doesn't work
I give up my car hates tach almost every tach installed except the Apexi SAFC has not worked
Old Jan 27, 2005 | 08:14 PM
mrspeaker's Avatar
Default Re: 89 Civic DX gauge clusters (EF Two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF Two &raquo;</TD></TR><TR><TD CLASS="quote">Which cluster works in the 88-89 Civic DX model? </TD></TR></TABLE>
The 88-89 civic si,civic lx clusters will work..
I put a 89 lx cluster into my old 88 std..No rewiring was neccesary..
Old Jan 28, 2005 | 10:36 AM
EF Two.'s Avatar
Default Re: 89 Civic DX gauge clusters (mrspeaker)
Anymore people that can verify that to Also anyone with a cluster with a tach that have tried it in their 88-89 CIVIC that works wanna sell it
Old Jan 28, 2005 | 10:42 PM
EF Two.'s Avatar
Old Jan 29, 2005 | 12:02 AM
l e o h j's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF Two &raquo;</TD></TR><TR><TD CLASS="quote">Which cluster works in the 88-89 Civic DX model? I've tried a few and none worked. I know the CRX cluster does not work. Does the 88-89 Civic SI cluster really work and can someone verify that. I got one but it doesn't work
I give up my car hates tach almost every tach installed except the Apexi SAFC has not worked </TD></TR></TABLE>
i got mine from a 89 civic lx (sedan) and it works just fine
here's a pic
just remember
if you have a 88 or 89 model get it from a 88 or 89 model sedan/hb/crx
if you have a 90 or 91 model get it from a 90 or 91 model sedan/hb/crx
Modified by leohj at 1:48 AM 1/29/2005
Modified by leohj at 2:08 PM 2/8/2005
Old Jan 29, 2005 | 12:35 AM
fastassdx's Avatar
From: Come back next year and Ill put some, eggnog in your face, US
I have an 1988 dx, with a crx Si dash cluster, and it works fine. The shape of the cluster is what is different between the 88-89 and 90-91 clusters in a civic or crx. All you have to do is use the (acording to what years) matching cluster cover. also honda did not make an civic Si in 1988.
Old Jan 29, 2005 | 05:04 AM
mrspeaker's Avatar
Default Re: 89 Civic DX gauge clusters (fastassdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastassdx &raquo;</TD></TR><TR><TD CLASS="quote">I have an 1988 dx, with a crx Si dash cluster, and it works fine. The shape of the cluster is what is different between the 88-89 and 90-91 clusters in a civic or crx. All you have to do is use the (acording to what years) matching cluster cover. also honda did not make an civic Si in 1988. </TD></TR></TABLE>
No,, its not just the shape of the cluster thats different between the years..
Old Jan 29, 2005 | 07:04 AM
Fred n J_v2.0's Avatar
I have an 89 Si cluster if your interested...
Old Jan 29, 2005 | 09:12 AM
nub.96ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">
No,, its not just the shape of the cluster thats different between the years..</TD></TR></TABLE>
Every USDM cluster will swap into it... and work. The fitting issue comes in as far as the hoods over the clusters which vary from 88-89 and 90-91. Either EVERY cluster you've tried is broken, or something else is wrong with ur car.
What is NOT working - need more info.
Modified by nub.96ek at 1:01 PM 1/29/2005
Old Jan 29, 2005 | 11:55 AM
fed's Avatar
fed
my 91 si cluster worked in my 91 std,
Old Jan 29, 2005 | 12:48 PM
OptimusPrimeX's Avatar
Default Re: 89 Civic DX gauge clusters (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">Every USDM cluster will swap into it... and work. The fitting issue comes in as far as the hoods over the clusters which vary from 88-89 and 90-91. Either EVERY cluster you've tried is broken, or something else is wrong with ur car.
Modified by nub.96ek at 1:01 PM 1/29/2005</TD></TR></TABLE>
exactly what i was going to say. The cluster bezel for 88-91 is shorter than the 90-91.. height wise.. So therefore.. grab yourself the NICER 90-91 and more viewable cluster, and get the 90-91 bezel. Correct me if i'm wrong, but there could be a chance that certain models have different connection pins that go into the Clusters????....
You could also use the 90-91 bezel and get yourself an integra cluster. I have myself this cluster, and i'm planning on re-wiring it when i get a chance.
Old Jan 30, 2005 | 07:54 PM
EF Two.'s Avatar
Default Re: 89 Civic DX gauge clusters (OptimusPrimeX)
I think every cluster I've tried is broken or they were from a CRX. My stock cluster works just fine just no tach
Old Jan 30, 2005 | 08:14 PM
fourthgenhatchB17's Avatar
&lt;---- 89 SI hatchback cluster in a 89 DX hatchback, no problems, plug N play
Old Jan 30, 2005 | 09:26 PM
fastassdx's Avatar
hey dude it does not matter if it is from a crx or a civic it will work. I did it myself. Check the wires going to your cluster, if the wire is cut that would make your tach work, then of corse your factory cluster will work, it does not have a tach on it. I have an 1988 HB and you could not get an Si in that year HB, but any cluster for 88-91 (civic or crx) with a tach will work in my car, there is something wrong with your car. If you can not fix this yourself then take it to someone who can. Have a nice day.
Old Jan 30, 2005 | 10:10 PM
EF Two.'s Avatar
All the wiring is fine. I never take my car to anyone. If I can't fix it I learn
Old Jan 30, 2005 | 10:51 PM
fastassdx's Avatar
well who put in your Apexi SAFC? The wire that it gets a signal from to work the Tach on it, would be the one the makes your factory Tach work as well.
Old Jan 30, 2005 | 11:23 PM
EF Two.'s Avatar
I did, the wire directly from the ecu and the blue wire behind the cluster both work. I don't have the SAFC anymore though
Old Jan 31, 2005 | 02:03 AM
Patch's Avatar
88-89 Civic/CRX (any model) clusters are interchangeable
90-91 Civic/CRX (any model) clusters are interchangeable
Trust me, I have an 89 and a 91, and I've swapped clusters in both. The plugs are different.
Old Feb 1, 2005 | 11:54 AM
fastassdx's Avatar
Default Re: 89 Civic DX gauge clusters (Patch)
I am going to pull my cluster out, and match them all up ,and takes some pics to end this post. will be back soon.
Old Feb 1, 2005 | 12:21 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch &raquo;</TD></TR><TR><TD CLASS="quote">88-89 Civic/CRX (any model) clusters are interchangeable
90-91 Civic/CRX (any model) clusters are interchangeable</TD></TR></TABLE>
Old Feb 1, 2005 | 02:37 PM
wpgcivic's Avatar
i put a whole crx si dash in my 89 dx
Old Feb 9, 2005 | 08:09 AM
roxy934's Avatar
hey DUDE, maybe you can help me with MY car. especially my clutch, and uh.... getting it back!! i figured i would hit you up here since you cant check your email.
Old Feb 9, 2005 | 09:17 AM
Speed PHreak's Avatar
Trust me, I have an 89 and a 91, and I've swapped clusters in both. The plugs are different.</TD></TR></TABLE>
No
88-89 CIVIC cluster's are interchangable and 88-89 CRX cluster's are interchangable, but not b/t the CRX and Civic chassis in the 88-89 years.
In 90-91 the Civic AND CRX had a common cluster wiring scheme.
The misinformation in this thread is ungodly.
Please consult this thread for the proper pin-outs
https://honda-tech.com/zerothread?id=709958
I've swapped numerous clusters around in all years ED/EF chassis cars, from DC2 LS and GS-R clusters, 96+ civic Ex clusters, 99-00 Si clusters, as well as a full digital Insight cluster.
Old Feb 9, 2005 | 12:01 PM
EF Two.'s Avatar
Default Re: 89 Civic DX gauge clusters (Speed PHreak)
Thanks for the info. I knew there was a difference between the 88-89 Civic and CRX clusters. So I thought I would ask. I guess I've just been getting CRX clusters.
Old Feb 9, 2005 | 04:02 PM
Patch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed PHreak &raquo;</TD></TR><TR><TD CLASS="quote">The misinformation in this thread is ungodly.
I've swapped numerous clusters around in all years ED/EF chassis cars, from DC2 LS and GS-R clusters, 96+ civic Ex clusters, 99-00 Si clusters, as well as a full digital Insight cluster.</TD></TR></TABLE>
I gave him the cluster information to the best of my knowlegde. Thanks for bashing me and everyone else for trying to help the kid. Go **** yourself.
