Toda B Vtec X-Over pt. and mods?
Old Jan 14, 2002 | 04:03 AM
comptechgsr's Avatar
Default Toda B Vtec X-Over pt. and mods?
mine is set @ 6700
-at the time i had a gsr cai, comptech header, and stock exhaust.
much has changed, but i gotta get it dyno tuned so i know where the new x-over is
Old Jan 16, 2002 | 01:51 PM
Incognito's Avatar
Default Re: Toda B Vtec X-Over pt. and mods? (comptechgsr)
I have Toda B's, and I set the VTEC to come on at 6200rpms, and disengage at 5800rpms.
sgT's Avatar
sgT
easy way to set it on the street is to put it where you cant feel the transition
Old Jan 16, 2002 | 01:53 PM
Austin's Avatar
Dino, I'm at 6950...cam gears at +5 IN, -5 EX, it was at 7450 with gears at +3.5 IN, +1 EX, changing the gears allowed me to move the limit lower, anything lower and there was a significant dip in the curve. Lawrence and I played for about 1 1/2 hours last time trying various combinations.
Austin
Old Jan 16, 2002 | 02:14 PM
JDM_DOHC_SiR's Avatar
New User
Mine is set at 5900 ...but anything less than that and you'll be wasteing your time on the dyno perhaps..
just my 2 Yen..
Old Jan 16, 2002 | 04:35 PM
mafay2's Avatar
New User
Default Re: Toda B Vtec X-Over pt. and mods? (JDM_DOHC_SiR)
Mine at 6700rpm and it is with AEM CAI, Spoon header, test pipe, and Kakimoto R exhaust.
Old Jan 16, 2002 | 05:49 PM
Black R's Avatar
25 Year Member
Default Re: Toda B Vtec X-Over pt. and mods? (Incognito)
Ditto! (Per Jack's suggestion.....)
Old Jan 16, 2002 | 06:02 PM
B18CXr's Avatar
Default Re: Toda B Vtec X-Over pt. and mods? (Black R)
A 300rpm delta from H to L works best.
Old Jan 16, 2002 | 06:44 PM
Mike K's Avatar
Default Re: Toda B Vtec X-Over pt. and mods? (B18CXr)
Best transition point I had was throwing them in a lake and putting my Spec A's back in.
Old Jan 17, 2002 | 07:50 AM
minh's Avatar
I may have the highest b-series x-over known to man (most cars don't rev as high as my VTEC x-over)...
7300 (redline isn't much higher 9100).
anything lower there is too much dip on dyno. at 7300 it's very smooth, (you can hear the change though).
[Modified by minh, 8:51 AM 1/17/2002]
Old Jan 17, 2002 | 07:57 AM
TypeR0149's Avatar
Default Re: Toda B Vtec X-Over pt. and mods? (Mike K)
Mike now how do you set that on a VAFC, do you have a diagram
I would still love to try the Toda B's i have had an itch to try them for the longest time, does Mike M still have His?
Old Jan 17, 2002 | 08:07 AM
Back in Black's Avatar
Rather OG
damn...i would have bought them for the hybrid project
jason- who prefers linear power
[Modified by Darth VadeR, 1:14 PM 1/17/2002]
Old Jan 17, 2002 | 08:08 AM
Rather OG
Default Re: Toda B Vtec X-Over pt. and mods? (minh)
wtf? post setup and plot please...i am curious
Old Jan 17, 2002 | 08:27 AM
Black R's Avatar
25 Year Member
.....doesn't sound too crazy to me. I've seen everything from 5800-7200, so 7300 sounds ok... You don't fall out of vtec at all? I'd expect 9500-10k rev limiter tho'.....
Old Jan 17, 2002 | 09:11 AM
Incognito's Avatar
What lake is this?
Old Jan 17, 2002 | 09:32 PM
Mike K's Avatar
Default Re: Toda B Vtec X-Over pt. and mods? (Vegeta)
Traded them to Jared for a set of Spec A's.
Jared is letting Josh use them in the 86mm LS/VTEC.
Ask Josh..
But remember Mike, I know you. You will NOT like the Spec B's. Plus, see how linear your is right now?
Compare it to other ITR's w/ the same mods and B's. LOL.
Old Jan 17, 2002 | 10:56 PM
GQ 05YellowEVO8's Avatar
threw it in a lake? You should have given them to me!
Old Jan 18, 2002 | 04:48 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
5100....flame away! actually, i never got to the dyno, and that is where my p28 is currently set. one day i will though...
Old Jan 18, 2002 | 04:52 AM
Rather OG
Default Re: Toda B Vtec X-Over pt. and mods? (rodney)
why flame?
jason- who's vtec was @ 5200 w/stock cams, i/h/e
Old Jan 18, 2002 | 01:34 PM
B18CXr's Avatar
I've heard B plots more linear than a MILF's ***!!
Old Jan 18, 2002 | 02:38 PM
minh's Avatar
Default Re: Toda B Vtec X-Over pt. and mods? (Darth VadeR)
here is a link to my dyno: http://www.clubsi.com/dyno_minh_1.shtml
you can also go to <gasp!> clubsi.com and go under "dyno" and under "allmotor" and click "Minh's Dyno 1 (Toda B)"
Old Jan 18, 2002 | 04:40 PM
Instg8er's Avatar
I didn't know you were suppost to put the VTEC x-over that high up! I had mine at 6K when I had the B's in... could I have made more power w/a higher switch over, or is that just to keep the transition smooth?
Old Jan 18, 2002 | 06:41 PM
Mike K's Avatar
ummm.. yea.
anyway, since you're in FL.. instead of taking I-95 home, you should take I-75. this will only make your entire road trip like 1.5hrs longer...
i can show you what some JUN cams can do.
i've already converted many toda fans.
IM me and I'll give u my cell number.
Old Jan 18, 2002 | 10:25 PM
555R's Avatar
oh no mike
your not gonna start with the Jun vs Toda thing again
BTW what kinda settings are you getting good results with Jun 3s
I have been playing around with a few combos with ok results
what I do know is the skunk prog is too rich...now I have the Jun prog
switchover is smooth without the vtec flutter they were known to have.
and at 7 grand the fun really begins...
what is a good x over? Im at 5700 with h/l at 5400
any thoughts?
Old Jan 19, 2002 | 08:00 PM
B18CXr's Avatar
JUN?????? converted.........
NEVER!!!!! I'll take my overpriced, non-peak hp having cams anyday.
