Are my Toda B's ok?
what valve train are you using? what is your valve lash set at???? did you TQ the cam caps in sequence (SP?) and to honda tq specs
I have seen this a few different cams before, i.e. Toda, Skunk and even some stock cams. My Toda B’s have some edges that look a bit rough too and I have had no problems with them. I have had them for well over 60k.
If you want you could touch them up a bit with a file then hit the edges with a buffer wheel. Just hit the edges enough to break the sharp edge and be careful not to hit the smooth part of the cam lobe.
I have seen this with the use of stiffer valvesprings on Toda cams.. My old ones were used in someone elses motor with 90lbs on the seat and this is what they look like now....I recomend a lighter spring and be carefull with you revs(because of the lighter spring..
Mashimaro
Dec 12, 2008 11:03 AM
luis666
Mar 21, 2006 09:07 AM
Blanket Jackson
30
Sep 29, 2004 11:12 AM
b18crx
Nov 21, 2003 10:56 PM
thanks guys
