92 VX Track Ready (Blowen motor) - San Diego, CA (beware 56k)
EDIT: 03/03/05
This will be sold running, unless you don't want it that way. I have 2 blocks, Car will be sold with both. One is .25mm over with CTR pistons, the other is Stock. It will not be streetable right away. You will need to install an exhaust and headers. Will be sold with the header it has now, Buyer warned ahead of time those are not street legal. Also if you want you will need put in the interior of the car (not included) if you want air or whatever.
Taking serious offers only. PM me for more details.
Will be roughly 4 weeks before it's together and running unless you want it as is (at the time you talk to me).
Original Posting:
1992 VX Hatchback
B16A fully bulit (Need extensive rebuild may need new motor, siezed up due to blockage in oil cooler lines)
-CompCams Stage 2 Cams
-CompCams Dual Valve Springs with Titanium Retainers
-ST Corsa Should Lock Cam gears
-Head has stage 2 port and polish Milled .010
-Custom Headers designed for High RPM Power (see pic)
-Mugen Head Gasket
-Greddy Timing Belt
-CTR pistons .25 over
-All new bearings
-Type-R oil pump (600 miles)
-ARP studs and bolts inside (everything)
-CTR pulley
-Skunk 2 Intake manifold
-Hondata Heat Shield Gasket
-Crane Cams Igntion Set (Capacitve)
-Ultra 8 Spark plug Wires
-OBX FPR
-Greddy Catch Can
-Custom Oil Cooler setup with Braid hoses
-AEM Fuel Filter with Earl's Braided Hose
-GSR CAlipers
-Project Mu Pads
-Brembo Rotors
-Earls Stainless Braided all 4 corners
-JDM Rear Disc Conversion
-ALL Bushing upgraded to Energy Poly-U
-Eibach Sway bars (Front and Back)
-All GSR Suspension Arms (if it matters)
-Blitz Intake filter
-Alum 1.5 inch dual row radiator (only water and water wetter)
-P28 Tuned ECU (running P30 code)
-Fields VTEC Controller (Should only used for minimal track side adjustments)
-S80 Type-R Tranny WITH OEM LSD with less then 1000 Miles (NEVER RACED)
-ACT Flywheel
-Clutchnet Carbon Fiber Clutch and 1X Pressure plate
-Carbon Fiber Strut Tower Bar
-No Names in back (upper and lower)
-Ground Control Coil-overs
-HammerHead Carbon Fiber hood (weighs 2.5 lbs and has 4k twill weave. 1 OF 3 MADE! Retailed for $750)
-OMP Seat
-Sparco 4 point (passenger)
-RJS 5 point (driver)
-5 Inch tach with recall and shift light
-Gauges (oil pressure, water temp, Exhaust temp, Volt)
Car is gutted. Nothing except the dash shell is left. No heater or anything thing else. The door panels are in also.
Probably more just can't remember. Also need to mention that it is registered with BAR to legally have a B16A. So if you buy the shell, you can throw in a b16 and smog it and it will be 100% legal. Sticker is still inside.
Hate to see her go. Has been a great bitch to me for 5 years.
Does NOT come with those rims.
PM Me for more. Make me an offer. Will not part out (yet).
Modified by qi_doy at 5:12 AM 3/3/2005
Original Posting:
1992 VX Hatchback
-Mugen Head Gasket
-Greddy Timing Belt
-All new bearings
-CTR pulley
-OBX FPR
-Greddy Catch Can
-GSR CAlipers
-Project Mu Pads
-Brembo Rotors
-ACT Flywheel
-OMP Seat
PM or post up with any reasonable offers.
FYI:
Shell included sway bars, roll bars, and brake setup as listed above. Also includes seats, harnesses and steering wheel. Can discuss gauges.
FYI:
After much debate with several users I have decided to list a prices. These are OBO but don't lowball me.
Shell only (includeds previous list): $2500
Complete everything Include hood and Type-R LSD Trans - $4500
