will LCA's from 92-95 work on our years?
Old Jan 27, 2005 | 06:35 PM
hxtasy's Avatar
Default will LCA's from 92-95 work on our years?
are 88-91 lower control arms the same as 92-93?
thanks.
also does any one know where to get some nice aftermarket ones for less than 100%??
Old Jan 27, 2005 | 06:50 PM
mrspeaker's Avatar
Default Re: will LCA's from 92-95 work on our years? (pennhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennhatch &raquo;</TD></TR><TR><TD CLASS="quote">are 88-91 lower control arms the same as 92-93?
No..
92-95 lca's are 1/16 inch longer..
They fit but give you added camber..
By the way 88 lca's are different from 89-91 lca's..
Old Jan 27, 2005 | 07:00 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennhatch &raquo;</TD></TR><TR><TD CLASS="quote">also does any one know where to get some nice aftermarket ones for less than 100%??</TD></TR></TABLE>
What is wrong with OEM Honda control arms?
Old Jan 27, 2005 | 07:07 PM
hxtasy's Avatar
Default Re: will LCA's from 92-95 work on our years? (Targa250R)
i like purrrdy ones
actually, junkyard wants 35$ a piece for them, bushings probably shot, so looking at like $80 why not some light weight ones taht look pretty and have bushings to go???????
i have tegra ones in now and they make it way too low
Old Jan 27, 2005 | 07:53 PM
91' LS-VTEC's Avatar
Default Re: will LCA's from 92-95 work on our years? (mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">
No..
They fit but give you added camber..</TD></TR></TABLE>
DAng, and my freind is trying to do this on his car as we speak. I should call him, but he started about 1hr ago. I'm shure he found out by now. Would that be neg or poss camber?
Old Jan 27, 2005 | 08:00 PM
mrspeaker's Avatar
Default Re: will LCA's from 92-95 work on our years? (91' LS-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91’ LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
DAng, and my freind is trying to do this on his car as we speak. I should call him, but he started about 1hr ago. I'm shure he found out by now. Would that be neg or poss camber?</TD></TR></TABLE>
Its the one that looks like this.. / \ I dont know technical terms..But its not that much camber ..
Old Jan 27, 2005 | 08:16 PM
ukdm crx's Avatar
If you had a camber kit wouldnt it be able to fix that problem
Old Jan 27, 2005 | 11:30 PM
BaYoNAiM's Avatar
Default Re: will LCA's from 92-95 work on our years? (ukdm crx)
i have it done already. i used eg shocks&coils.
its direct fit and its negative chamber.
MasterFunk
Dec 12, 2007 05:25 AM
kardal86
Jul 31, 2007 12:41 PM
iperez
Dec 27, 2006 09:39 AM
boostedpleasure
Jun 30, 2006 04:06 PM
daidilus
Feb 20, 2005 09:37 PM
