DC5 TYPE R CAMS in a 03 K24a?
Old Jan 27, 2005 | 06:17 PM
dj_audio's Avatar
Default DC5 TYPE R CAMS in a 03 K24a?
I have a question. Does anyone know if it is possible to put some DC5 ITR cam shafts into a k24 head? I've found some cheap JDM DC5 ITR cam shafts online, but im wondering if it will run in a k24 head. I know for a fact that all K series motors have DOHC but only single side VTEC. The only K series motor with dual side VTEC is both the USDM Acura RSX type S and the JDM Integra Type R. Will the camshafts work in the head even though the k24 has VTEC running only on the intake cam?
Old Jan 27, 2005 | 06:39 PM
fw190bvi's Avatar
Default Re: DC5 TYPE R CAMS in a 03 K24a? (dj_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj_audio &raquo;</TD></TR><TR><TD CLASS="quote">I have a question. Does anyone know if it is possible to put some DC5 ITR cam shafts into a k24 head? I've found some cheap JDM DC5 ITR cam shafts online, but im wondering if it will run in a k24 head. I know for a fact that all K series motors have DOHC but only single side VTEC. The only K series motor with dual side VTEC is both the USDM Acura RSX type S and the JDM Integra Type R. Will the camshafts work in the head even though the k24 has VTEC running only on the intake cam?</TD></TR></TABLE>
um...dual cams, but only one side has vtec lobes...???....im not a K series expert, but are you sure?????.......i thought the k20-r heads were a direct swap onto the k24 block....wouldnt the conversion to dual cam vtec require different oil lines/routes/etc, or at least fuel maps?
Old Jan 27, 2005 | 07:18 PM
norcalcrx's Avatar
Im 90% certain you cannot swap dc5 cams into a k24a head. You can swap the dc5 head onto the k24 block though.
Old Jan 27, 2005 | 08:50 PM
dj_audio's Avatar
Default Re: DC5 TYPE R CAMS in a 03 K24a? (norcalcrx)
so in other words, if i wanted those cams to run on my k24 i'd have to swap the dc5 head onto the k24a block? Because yeah, im sure the entire k series has dohcs but the vtec spools only on one side. I guess it makes sense you would need to swap over the entire dc5 head. Thanks
Old Jan 28, 2005 | 08:00 AM
civicminded92's Avatar
Not only a head swap, but an ECU swap/reprogram also.
Don't forget that there is also a k24 with performance VTEC - it's found in the Acura TSX.
Old Jan 28, 2005 | 10:23 AM
Turbowa's Avatar
Default Re: DC5 TYPE R CAMS in a 03 K24a? (civicminded92)
Also the K series of engines are all chain driven and the older Honda engines were all belt driven.
Diyracing2
Sep 2, 2015 09:35 PM
billyekracer
Jul 13, 2010 06:37 PM
ILuvMyJdmDc4
Nov 15, 2008 03:36 PM
AllMTRWH0R3
Feb 18, 2005 10:18 AM
dj_audio
Acura TSX
Feb 8, 2005 08:38 PM
