BARO! 1988 Crx Hf This One has got me beat? Knoledge from the wise ones I beg!
I have replaced the sensor in my passenger side kick panel but the light still comes on and the code is still there. Even after I kept the computer out over night. The code comes on even befor inital start up. This ones got me beat?
Help?
Help?
Generally speaking, if replacing a sensor does not correct the problem, then the problem is probably in the wiring between the sensor and ECU, or the ECU itself. The baro sensor itself has three wires: power, ground, and output. I don't remember what the colors are on the wires. But you could take a look at a manual. First, there MUST be continuity between the output pin on the sensor and the pin on the ECU plug. Check to make sure that this is the case. Also check to make sure that there is about 5 volts between the power and ground while the key is turned on. If no problems are found, try replacing the ECU.
tgmueller
Apr 29, 2013 10:42 PM
THE FUCATYPR HATCH
Jan 27, 2005 10:13 PM
