Engine Stuff- Hmotors
Old Jan 27, 2005 | 04:15 PM
.Thomas's Avatar
Default Engine Stuff- Hmotors
When you buy a motor from them should you just buy the motor or the "complete" change over? it sounds like the motor, has everything you need am i wrong?? -Thanks
Old Jan 27, 2005 | 04:23 PM
cbp_crx's Avatar
Default Re: Engine Stuff- Hmotors (flatblkCR-X)
what motor are you looking at purchasing and what do you have for a car civic/crx/ dx/si/ hf?
Old Jan 27, 2005 | 04:29 PM
cbp_crx's Avatar
Default Re: Engine Stuff- Hmotors (crx_si6)
well anyway to answer your question the motor does pretty much come complete, but it really depends on what swap you want to do
Old Jan 27, 2005 | 08:18 PM
.Thomas's Avatar
B18c5 in a 91' CRX Si My goal is to keep it stock and only add a lighter flywheel and get it BARed
Old Jan 27, 2005 | 08:21 PM
mrspeaker's Avatar
You get the complete swap..
But you need to buy b-series motor mounts
You have to convert to hydro to run that tranny
You have to convert your car's obd to match the motors obd or vice versa..
Some other **** to
b18c5 swap is a very hard swap..Its gonna cost a lot..But if you got the money go for it..
Old Jan 27, 2005 | 08:24 PM
.Thomas's Avatar
Default Re: Engine Stuff- Hmotors (mrspeaker)
is B18c5 and lot more than a B18c1, i know the motor is cheaper in C1, but is the swap more expensive besides that?
Old Jan 27, 2005 | 08:25 PM
rtmiami's Avatar
HAS Sport actually makes mounts/mechanisims to run the hydro tranny's
it's pretty cool
Old Jan 27, 2005 | 08:28 PM
PHOBIA's Avatar
honestly why bother with the R ,why not turbo a gsr or b16?
Old Jan 27, 2005 | 08:31 PM
mrspeaker's Avatar
Default Re: (PHOBIA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">honestly why bother with the R ,why not turbo a gsr or b16?</TD></TR></TABLE>
Then he wouldn't be able to say he has a type-r motor..
I agree b18c is much more cost effective then the b18c5..
Old Jan 29, 2005 | 10:40 AM
.Thomas's Avatar
Default Re: (mrspeaker)
How do you get a turbo GSR smogged in CA? if it can be done then tell me how, i was just thinking of keeping everything stock so smogg wont be a huge deal
Old Jan 29, 2005 | 11:33 AM
88civichbz6's Avatar
chip your ecu so when you go to get tested it runnings a little lean.when i go to the testing station i pull in a lot near it switch to a lean chip go in test then go to the lot and switch it back out. i passed my last one with out a cat. on my z6. they didn't even look under my car. but they where slamed that day.
Old Jan 29, 2005 | 09:53 PM
PHOBIA's Avatar
its going to be a lot easier to turbo a swapped gsr and get the turbo setup approved also with a stock gsr motor.
eagarcia88
Sep 22, 2011 12:06 PM
itellyawhat
Oct 16, 2004 10:07 AM
Honda_lmport_727
Jun 11, 2004 10:36 PM
lobo
Feb 11, 2003 12:42 AM
