Taking off flywheel
yea, u might need an impact for that. those bolts are know for stripping cuz there not that thick like a regular bolt. get the 12 point 17 mm socket -preferably a short one (also u can use a standard size socket, forgot what size it is though). get it in 1/2 inch drive and use a 1/2 drive impact gun to get it out. push ur weight on the gun and bolt and hit it with the impact to avoid stripping it. i hate flywheel bolts!
Stick a tranny bolt in and wedge a 2x4 piece of wood between the
the bolt and the flywheel.
That should be enough to keep the flywheel stationary
while you break the bolts loose
FAQ: removing flywheel using nothing but a ratchet, 17mm 12pt socket and 9/16th box wrench? no preob
BlueShadow
14
Jul 31, 2004 04:45 AM
jondancer
10
Apr 18, 2003 07:19 AM
The major companies have it, you can get it from sears but they might not have it in stock.
