ITR muffler - restrictive? does it fit?
Old Jan 13, 2002 | 11:25 PM
HX_Guy's Avatar
Default ITR muffler - restrictive? does it fit?
How good is the performance of a Type R muffler? Would it lose alot of performance over a straight though 2.5" muffler?
My ES Tuning muffler is getting annoying and Im considering a ITR muffler for my '97 Civic...would it be a direct bolt on?
Old Jan 13, 2002 | 11:27 PM
Yellow Dragon's Avatar
Default Re: ITR muffler - restrictive? does it fit? (HX_Guy)
I don't think it will be a direct bolt up. Not 100% sure though.
I would find something more straight through design. The ITR stock muffler is better than most stock mufflers...but still restrictive IMO.
Old Jan 13, 2002 | 11:49 PM
HX_Guy's Avatar
Default Re: ITR muffler - restrictive? does it fit? (Yellow Dragon)
Someone local is selling one, I think Ill pick it up and dyno it. If it only loses a couple HP over the ES muffler...it will be worth it. Im way way WAY tired of my muffler.
I want something quiet...like stock quiet.
Old Jan 14, 2002 | 05:48 AM
cjb92's Avatar
you should go for it. I know what itr muffler you are talking about it's like $100 or something. I imagine you could get it to fit and it will be much quieter maybe a little restrictive. Or buy a 22in resonator from magnaflow at midas or from SMSP on this board, that might help also with the ES.
Old Jan 14, 2002 | 05:49 AM
Mike K's Avatar
It fits on a coupe fine. You've gotta extend it like 2 or 3 inches, and thats all.
Not sure how restrictive it is compared to a straight-thru muffler, but I made 184/130 @ the wheels w/ stock exhaust, dc jdm header and toda spec A cams.
Old Jan 14, 2002 | 06:17 AM
HX_Guy's Avatar
Default Re: ITR muffler - restrictive? does it fit? (Mike K)
Is that pretty typical for an ITR w/ those mods that has a straight thru muffler? Do they usually put out more?
Old Jan 14, 2002 | 08:07 AM
lucas569's Avatar
do you have a cat and a resonator in placre now? eliminating either (or both) will make your **** loud. slapping the itr muffler on is just a matter of running to the muffler shop and getting it welded on. $50 procedur.
Old Jan 14, 2002 | 08:08 AM
HX_Guy's Avatar
Default Re: ITR muffler - restrictive? does it fit? (lucas569)
I dont have a cat...but I do have a resonator. Maybe I should try a hi-flo cat first?
Old Jan 14, 2002 | 08:25 AM
lucas569's Avatar
yup,i would. removing the cat makes a hell of a difference in sound levels. just hit up ben@importparts.com for a 2.5" carsound cat for $99,bring it to muffler shop and theyll weld in the o2 sensor and all. should be $50-$60.
this will quite things up alot!
Old Jan 14, 2002 | 08:26 AM
HX_Guy's Avatar
Im not worried about the welding part, I can do that. I guess Ill go that route first.
Old Jan 14, 2002 | 08:38 AM
onyx00's Avatar
Funny, someone in Phoenix tried to take my muffler the other day...*ahem* *cough* HX Guy
Old Jan 14, 2002 | 08:56 AM
EleanoR's Avatar
Lucas? the carsound cat is only $99 from ben at import? i got mine through SMS (dave) and i didn't shop around and paid a fortune for it compared to that price. hmmm....is that the 94006 model?
-Mike
Old Jan 14, 2002 | 09:11 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: ITR muffler - restrictive? does it fit? (talkie25)
-Mike
SMSP's Carsound deal is a direct bolt-on, if I'm not mistaken. The $99 price is probably cat only - you'll still have to get it welded to fit.
Old Jan 14, 2002 | 09:14 AM
HX_Guy's Avatar
Default Re: ITR muffler - restrictive? does it fit? (itr009)
Landspeed Racing sells the cat only for $65..I know where Im buying mine from
Old Jan 14, 2002 | 09:17 AM
Splat's Avatar
Or you can get a generic 2.5" cat from Jeg's for $50
Old Jan 14, 2002 | 09:24 AM
Todd00's Avatar
I said I don't want a title!
Where do you extend it at? Where it bolts onto the b-pipe? I was going to let a friend use my oem ITR muffler on their 99 EX Coupe, but I don't want them to hack it up.
Old Jan 14, 2002 | 10:56 AM
sgT's Avatar
sgT
Runto made 195whp with spec C, honda 4-1 and stock itr exhaust.
I was more than surprised.
Old Jan 14, 2002 | 10:58 AM
Black R's Avatar
25 Year Member
Default Re: ITR muffler - restrictive? does it fit? (sgT)
hrmness.....
Old Jan 14, 2002 | 12:53 PM
lucas569's Avatar
yes that is true, but taking it to the muffler shop isnt really that much of a biggee...$40-$60
unless of course you like doing it yourself,in that case i would get the one from smsp.
Lucas? the carsound cat is only $99 from ben at import? i got mine through SMS (dave) and i didn't shop around and paid a fortune for it compared to that price. hmmm....is that the 94006 model?-MikeSMSP's Carsound deal is a direct bolt-on, if I'm not mistaken. The $99 price is probably cat only - you'll still have to get it welded to fit.
Old Jan 14, 2002 | 02:13 PM
brinks's Avatar
Resonated test pipe
Old Jan 14, 2002 | 03:42 PM
gamby's Avatar
Default Re: ITR muffler - restrictive? does it fit? (brinks)
I've seen pics of it done on a 99 Si where the tip was extended an extra 2" so it would meet the edge of the bumper. (cut off stock tip, weld in 2" long piece of pipe, re-weld stock tip) It looked OK. Very stealthy.
mynameizstitch
15
Jul 12, 2009 12:53 PM
lsteggy
Oct 26, 2002 02:21 AM
forksports
May 11, 2002 10:02 PM
No-Gi
Apr 9, 2002 06:29 AM
threatcon13
Nov 15, 2001 06:11 PM
