#1 fuse help
well my std keeps blowing the number one fuse. Ive looked thru my near worthless haynes manual. I can tell that it works signals, gauges, seatbelt chime, seatbelt light, and more that i dont know.
i noticed a few minutes ago that it would not blow the fuse untill i started the car. Any leads to what else runs off this fuse or how a starting/running the car would blow it vs. just having the ignition switch on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom5th »</TD></TR><TR><TD CLASS="quote">anybody have a fsm
http://www.honda.co.uk/owner/workshopmanuals2.html
There are downloadable versions if you search around a little.
</TD></TR></TABLE>http://www.honda.co.uk/owner/workshopmanuals2.html
In my 91 Civic/CRX/SI manual(don't know what your year is),but the number 1 fuse powers;
Intergrated control unit(IG1)
Automatic seat belt control unit(USA)
Turn signal lights
Clock(IG1)
Back-up lights
Gauges and warning lights
Dimming ciruit(HF model only.economy driving indicator)
Speed sensor
Shift lock selenoid
Shift lever position indicator
Interlock control unit
Hope that helps you.
Turn signal lights
Clock(IG1)
Back-up lights
Speed sensor
Shift lock selenoid
