ECU wiring problems
Does anyone know which wires are the TPS, Collant, RPM, and O2 Signal for a 2000 TypeR? I"m trying to install the O2 Sensor simulator, but i couldn't find the wires the instruction specifiy. As i recall, 97-98 Rs have different ECU than 00-01 Rs. Am I correct? Please help if you have the ECU Diagram for the 00 R.
Sorry I can't help you with the wiring, but I can warn you that your dealer may not warranty the ECU if you tamper with the ECU harness. That happened to me when I installed a A/F meter in my '98 ITR...
