Remocing AC - JDM aluminum AC bracket or no AC bracket at all?
Old Jan 27, 2005 | 06:29 AM
Renegade's Avatar
Default Remocing AC - JDM aluminum AC bracket or no AC bracket at all?
I removed my AC last weekend, with that, The AC condenser is, of course, on a bracket that is bolted onto the block. This bracket extends out towards the wheel and is attached to a weak and small version of motor mount attached to the frame, which to me, seems to not do much, but if I was to reinforce the mount , perhapst make it a solid one it may help.
Any advantages to keeping the AC bracket? If yes Iwould get the JDM aluminum 2.4lbs bracket and chuck the 7 lbs stock one.
Thanks
I did a search all I was able to find was how to remove the AC none mentioned anything abotu the bracket.
Old Jan 27, 2005 | 06:46 AM
IN VTEC's Avatar
Default Re: Remocing AC - JDM aluminum AC bracket or no AC bracket at all? (Renegade)
Do not remove the bracket. Leave the original one on there or switch to the aluminum if you want.
Old Jan 27, 2005 | 07:11 AM
Erik95LS's Avatar
Default Re: Remocing AC - JDM aluminum AC bracket or no AC bracket at all? (IN VTEC)
yeah that mount is fairly important. If you can't stand having the stock one on there, just get the lighter one.
Old Jan 27, 2005 | 09:18 AM
B2FiNiTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Do not remove the bracket. Leave the original one on there or switch to the aluminum if you want.</TD></TR></TABLE>
Exactly. That bracket serves as a vibration dampener as there is one on each side.
Old Jan 27, 2005 | 12:50 PM
Renegade's Avatar
Default Re: Remocing AC - JDM aluminum AC bracket or no AC bracket at all? (B2FiNiTY)
Thanks for the replies it is all god info.
So I guess stiffening the bushing is out of the question as well.
Old Jan 27, 2005 | 12:54 PM
esponet's Avatar
i know a person that did not have that mount, his v/c would hit the hood when he takes off.
the only time i have seen someone run without it sucessfully was with the use of solid mounts on the eng,tranny, rear.
Old Jan 27, 2005 | 04:55 PM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade &raquo;</TD></TR><TR><TD CLASS="quote">So I guess stiffening the bushing is out of the question as well.</TD></TR></TABLE>
You could still get a harder mount, insert, or solid mount for it.
Old Jan 28, 2005 | 07:12 AM
bitzbp's Avatar
Default Re: Remocing AC - JDM aluminum AC bracket or no AC bracket at all? (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">
You could still get a harder mount, insert, or solid mount for it.</TD></TR></TABLE>
Yea they make poly inserts for those mounts. I have a set in my GF's gsr. You will feel more vibration though. I think the ones I have are made by Energy Suspension or something like that.
Old Jan 28, 2005 | 07:39 AM
- Sim -'s Avatar
Default Re: Remocing AC - JDM aluminum AC bracket or no AC bracket at all? (bitzbp)
omg
what problems causes the braket?
20 kg ?
go with the alu one if you re a weight saver deluxe
psi2high
May 3, 2011 03:48 PM
All Day
Jun 29, 2005 10:08 AM
SLeePeR012
Feb 21, 2004 04:43 PM
NeXtLeVeL_TyPe_R
Nov 24, 2002 07:47 PM
