auto manual swap no vtec
yo - i did this auto-to-manual swap, and since then i haven't had vtec kick in. i have good oil pressure, car was warm when i tried (a lot) and it just seems to get slower at high rpms, whereas before it would rod normally (heh, rod) does it have anything to do with the fact that the car thinks its in park? i have no check engine lights.
yeah, i changed the ecu to a manual (by taking out 2 resistors and soldering in a jumper) ill check my timing tomorrow morning, and see if that's the problem. would vtec not kick in if its too advanced, or retarded? i guess not, since that's what you're saying. hmm
i think you should use a completely different computer...that was made for a manual
especially if your not throwing any cel's.... your timing my be messes up or your rigged computer could be takin a ****..but i cant tell from here.. lmk what you figure out
i tried kicking... i tried yelling at it... ive tried adjusting the timing, havent tried a different ecu. my speedometer works fine
i just tried 2 different ecus and thats not it. broken wire maybe somewhere in the wiring? we did have to move a lot of **** to put the hydraulic lines in...
