stainless brake hoses
Old Jan 27, 2005 | 12:35 AM
ErrDizzle's Avatar
Default stainless brake hoses
i's installing a 5 lug conversion from a ITR into my EK.
i want to get stainless brake lines for the swap. so do i use integra r lines or civic ones. also are all dc2 integra brake lines the same. i tried searching for type r stainless lines and mostly came up with ls/gs/gsr lines only. i know the itr rear calipers are the same as gsr calipers, but the fronts are different.
Old Jan 27, 2005 | 12:09 PM
ErrDizzle's Avatar
BUMP for some help
Old Jan 27, 2005 | 12:16 PM
pdiggitydogg's Avatar
you want them for an civic em1 si, as integra lines are longer
Old Jan 27, 2005 | 11:26 PM
ErrDizzle's Avatar
but are the calipers on SIs and ITR located differently. are all integra lines the same or are ITRs different
Old Jan 27, 2005 | 11:27 PM
SOHC4life 96's Avatar
Default Re: (a_kaibigan)
Just have a shop custom make you some lines.
Old Jan 28, 2005 | 04:25 AM
theyre the same location as far as I know
why not search for those that have the itr calipers and ask what hoses theyre using - which Im sure will be ex/si lines up front
(so you'll want the em1 lines)
Old Jan 28, 2005 | 06:38 AM
overrev130's Avatar
Default Re: stainless brake hoses (a_kaibigan)
The ss brake lines are the same.92'-95' civic with rear disc and 94'01' integra with rear disc. It's all the same. But not the newer civics.
Old Jan 28, 2005 | 07:39 AM
JeffS's Avatar
Integra (any 94-01), or Civic Si (99-00) lines are what you want.
Old Jan 28, 2005 | 07:42 AM
Built to Spill's Avatar
el diablo
Default Re: (pdiggitydogg)
Im using my stock lines. Stainless is the way to go.
Old Jan 28, 2005 | 08:35 AM
But arent most integra lines longer than civic lines?
Creates uneccesary distance, volume, and could result in damage to them from slack (if not secured away from rotation)
Side note: I recommend TechnaFit lines from KingMotorsports (good price and are caoted w/ an outter plastic shield to protect mesh)
Old Jan 28, 2005 | 09:37 AM
el diablo
Yeah they are longer, but im using my stock civic lines on my ITR setup.
Old Jan 28, 2005 | 12:06 PM
ErrDizzle's Avatar
thanks
Old Jan 28, 2005 | 12:54 PM
Jon V's Avatar
I got braided SI lines on my EK hatch with my 5 lug...
Old Jan 31, 2005 | 09:29 AM
Si Integra's Avatar
Default Re: (Jon V)
This is an odd question that I am also looking for the answer to. I have a LS 95 dc teg and recently purchased a set of ss lines for it. While waiting for shipping, i did a little research and found out that type r's have different part #'s than any other ls, gs, rs, gsr, etc.
What are the diffierence in type r vs. the other dc tegs?
Will the type r lines work for me? Thanks for the help and sorry if I am jacking your thread, I just seen it while searching and figured it better than creating a new one for a similar answer
Old Jan 31, 2005 | 09:35 AM
Jon V's Avatar
Default Re: (Si Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Integra &raquo;</TD></TR><TR><TD CLASS="quote">This is an odd question that I am also looking for the answer to. I have a LS 95 dc teg and recently purchased a set of ss lines for it. While waiting for shipping, i did a little research and found out that type r's have different part #'s than any other ls, gs, rs, gsr, etc.
Will they work? probly...
will they work any better... nope...
i am not sure what the difference is but if anything it is probably just a little difference in length...
Old Jan 31, 2005 | 09:47 AM
Si Integra's Avatar
Default Re: (Jon V)
I was not expecting any performance gain from "type r" lines. I got a good deal and purchased them to add to my wilwood brake setup.
I beleive the lines are going to be different in size. The concern i have is, are they going to be too long (I hope) or too short?
el diablo
Im almost positive that the length of the lines of any integra are the same. The only difference would be the width of the lines. If the width is different, that would promote better brake fluid flow throughout the lines, which would cause better braking. I might have to check on this though.
Old Jan 31, 2005 | 09:49 AM
Si Integra's Avatar
Default Re: (Built to Spill)
if you do not mind, please do so nd get back to me
Old Jan 31, 2005 | 09:58 AM
el diablo
The size and length of all integra brake lines are the same. The only difference is the brake hose mounting bolts. The brake hose mounting bolts are the same on gsr's and Type r's (98-01), but different on ls's.
So your R lines will work but you might have to zip tie them in place
Old Jan 31, 2005 | 10:07 AM
Si Integra's Avatar
excellent. I can buy mounting brackets or use brackets similar to the ones that hold the harness for the alternator. The ones that fold around the line then have a hole for a bolt.
Thanks a ton!
NOOdS
Sep 11, 2012 02:03 PM
StillGotIt
Mar 1, 2006 02:17 PM
numero sete
Jan 6, 2006 12:01 PM
