not a zc
Old Jan 26, 2005 | 08:55 PM
chrisblack's Avatar
Default not a zc
are dohc d16a1 the same as the dohc zc
Old Jan 26, 2005 | 08:57 PM
31flavorscivic's Avatar
Default Re: not a zc (chrisblack)
I am unsure whether d16a1 was DOHC or not, but what I do know is they are not the same. d16a1 only has 100hp. DOHC ZC has 130 HP and comes from japan. Do not get the d16a1, its not really worth it.
Old Jan 26, 2005 | 09:05 PM
chrisblack's Avatar
Default Re: not a zc (31flavorscivic)
it is a jdm d16a1 and it dohc
Old Jan 26, 2005 | 09:43 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisblack &raquo;</TD></TR><TR><TD CLASS="quote">it is a jdm d16a1 and it dohc </TD></TR></TABLE>
There is no JDM d16a1. JDM engine codes have 4 digits, not 5 .
Old Jan 26, 2005 | 09:47 PM
chrisblack's Avatar
Default Re: not a zc (fast88std)
it is a d16a1 and it is a jdm
Old Jan 26, 2005 | 09:48 PM
ServiceAdvisor's Avatar
D16a1 = USDM 88-89 Acura Integra 1.6L DOHC
Known widely as a "Brown top ZC" Only fits the 84-87* chassis Civic/Crxs' and makes approximately 125ps. - Darrell
* = Not exactly sure.
Old Jan 26, 2005 | 09:51 PM
chrisblack's Avatar
Default Re: (DOHCZCCRXSi)
it is a black top
Old Jan 26, 2005 | 10:42 PM
Default Re: (chrisblack)
I am like 99% that if it has a # at the end, it is usdm. The d16a1 was from 88-89 teg. trust me.
Old Jan 26, 2005 | 10:43 PM
elrandeeto's Avatar
somethings not right ^^^^^ i agree from what ive read im pretty certain the number on the end it usdm not jdm
Old Jan 27, 2005 | 12:34 AM
Reason's Avatar
Default Re: (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">I am like 99% that if it has a # at the end, it is usdm. The d16a1 was from 88-89 teg. trust me.</TD></TR></TABLE>
d16a1 came from the 86-89 teg.
86-87 was brown top and 88-89 was black top.
this is not a JDM engine, it is the usdm version of the dohc zc.
Old Jan 27, 2005 | 02:08 AM
efcivic757's Avatar
They are pretty much the same motor and you can put them in the 88-91 civics also not just 84-87. I have personnally seen one in a crx.
Old Jan 27, 2005 | 04:23 AM
StorminMatt's Avatar
Default Re: (efcivic757)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efcivic757 &raquo;</TD></TR><TR><TD CLASS="quote">They are pretty much the same motor and you can put them in the 88-91 civics also not just 84-87. I have personnally seen one in a crx.</TD></TR></TABLE>
In order to pull this one off, a custom driver side bracket would be required.
Old Jan 27, 2005 | 07:40 AM
jlicrx's Avatar
there are no JDM D16A1 engines - the JDM engines in the Integra are ZCs which are essentially the same as the D16A1 with different cams, different pistons on brown top - 86-87 JDM ZC had brown valve cover and vacuum advance ignition - 88-89 JDM ZC had balck valve cover and electronic advance ignition - the JDM Integra engines bolt right into 1g CRX and 3g Civic, using USDM 86-89 Integra transmission, axles, knuckles/hubs and shift linkage - they do not bolt into 2g CRX or 4g Civic, mainly because they have different mounts and use a totally different transmission - they use the 86-89 Integra transmission - the ZC that bolts into the 2g CRX and 4g Civic is black valve cover from JDM CRX/Civic Si - it is a completely different engine from the Integra ZCs and the D16A1 - shares some internal parts, but it is mostly different - has same mounts and a version of the same transmission as the 2g CRX and 4g Civic
Old Jan 27, 2005 | 08:04 AM
ZCcivic91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">D16a1 = USDM 88-89 Acura Integra 1.6L DOHC
* = Not exactly sure. </TD></TR></TABLE>
125ps, isnt that about 120-123 HP? Correct me if Im wrong. From everything I have ever read on this motor (and yes it is a USDM Teg Motor) made 112hp, not 125. Anyone know this for sure?
It does NOT bolt into any 4th gens, but is a good replacment in the 3rd Gen vehicles.
Old Jan 27, 2005 | 08:13 AM
Robster Craw's Avatar
Default Re: (ZCcivic91)
D16a1= teg motor as said above
will not work in a 4th gen civic/ 2nd gen CRX
Does fit in 85 to 87 CRX Si's directly
Old Jan 27, 2005 | 08:27 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCcivic91 &raquo;</TD></TR><TR><TD CLASS="quote">125ps, isnt that about 120-123 HP? Correct me if Im wrong. From everything I have ever read on this motor (and yes it is a USDM Teg Motor) made 112hp, not 125. Anyone know this for sure?
It does NOT bolt into any 4th gens, but is a good replacment in the 3rd Gen vehicles.</TD></TR></TABLE> The 86-87 USDM D16A1 (browntop, vac. advance) makes 113hp. The 88-89 USDM D16A1 (blacktop, elec. advance) makes 118hp. They ARE NOT the same as most of the dohc JDM ZC engines and they DO NOT easily swap into 88+ civics/crxs!
Search...
http://www.g1teg.org
http://www.redpepperracing.com
http://www.thezcresource.com
Old Jan 27, 2005 | 09:47 AM
julio_bOostamante's Avatar
I'm a Jackass
The 88-89 are black tops and dont bolt up in the 4th gen civics. in order for them to work your gonna have to remove the power steering bracket.
other than that the brown tops are the ones that drop into the 3rd gen civics.
BTW you can boost the black or brown tops and it wont matter that they only have 100 HP http://www.homemadeturbo.com is your friend
Old Jan 27, 2005 | 09:51 AM
mrspeaker's Avatar
Default Re: not a zc (julio_bOostamante)
The d16a1 isnt worth the time,effort and money to put in to the 88-91 chassis..
Dont get me wrong ..if I lived in bumfuck,alabama and no one lives around me for miles and I got the d16a1 for free and I had a civic shell,,I would try to put it in the car ..
Old Jan 27, 2005 | 10:08 AM
Reason's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">there are no JDM D16A1 engines - the JDM engines in the Integra are ZCs which are essentially the same as the D16A1 with different cams, different pistons on brown top - 86-87 JDM ZC had brown valve cover and vacuum advance ignition - 88-89 JDM ZC had balck valve cover and electronic advance ignition - the JDM Integra engines bolt right into 1g CRX and 3g Civic, using USDM 86-89 Integra transmission, axles, knuckles/hubs and shift linkage - they do not bolt into 2g CRX or 4g Civic, mainly because they have different mounts and use a totally different transmission - they use the 86-89 Integra transmission - the ZC that bolts into the 2g CRX and 4g Civic is black valve cover from JDM CRX/Civic Si - it is a completely different engine from the Integra ZCs and the D16A1 - shares some internal parts, but it is mostly different - has same mounts and a version of the same transmission as the 2g CRX and 4g Civic </TD></TR></TABLE>
dohc zc's also came in the crx's in japan.
fernruffryders
May 24, 2006 11:38 AM
rice_rocket_91
Jan 31, 2005 05:52 PM
JapJunkie
19
May 5, 2004 09:10 PM
SpeedMonkeyRacing
Mar 3, 2003 03:10 PM
ZCRX
Mar 7, 2002 08:35 AM
