Type R Throttle Body Installation Problem on my D-series motor
Old Jan 26, 2005 | 08:33 PM
wushubrian's Avatar
Default Type R Throttle Body Installation Problem on my D-series motor
Alright heres the deal, I have the skunk2 intake manifold for my d16y7. Will I have to port match the Integra type R throttle body to it because I think the skunk2 intake manifold already has a bigger openning. Plus I currently have a civic throttle body spacer and was wondering if this would fit. OR do I have to get the integra spcacer instead of the civic one. If someone could please help me with this. Thank You.
Old Jan 26, 2005 | 11:21 PM
Katman's Avatar
Default Re: Type R Throttle Body Installation Problem on my D-series motor (wushubrian)
im not sure if the skunk2 D manifold's plenum matches the diameter of the ITR TB's, but if it doesn't, yes its a good idea to match port it. You can reuse your D-series TB gasket, but you'll have to widen the diameter size of it with some scissors, or just buy an ITR TB gasket...
Old Jan 27, 2005 | 07:01 AM
IN VTEC's Avatar
Depending on how much you have to bore over the manifold's inlet, you can use a cylinder honing tool/stones on a drill. Anything more than a millimeter will probably need carbides, stones, or a lot of cartridge rolls.
I would get the ITR TB gasket. They're cheap.
Old Jan 27, 2005 | 12:26 PM
djsgtrip's Avatar
Default Re: Type R Throttle Body Installation Problem on my D-series motor (IN VTEC)
I have a Skunk2 D16 I/M, and the opening is about 61-62mm. So your type-r throttle body should bolt on and match very well since the TB is 62mm.
Old Jan 27, 2005 | 01:14 PM
wushubrian's Avatar
Default Re: Type R Throttle Body Installation Problem on my D-series motor (djsgtrip)
Alright. Thx. I appreciate the info. Any idea if my spacer will fit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsgtrip &raquo;</TD></TR><TR><TD CLASS="quote">I have a Skunk2 D16 I/M, and the opening is about 61-62mm. So your type-r throttle body should bolt on and match very well since the TB is 62mm.</TD></TR></TABLE>
Old Feb 3, 2005 | 04:39 PM
14bcoupe's Avatar
im pretty sure it ll fit but wouldnt the opening on the spacer be too small
95egianp
Mar 18, 2013 04:46 PM
wushubrian
Jan 27, 2005 01:57 PM
wushubrian
Welding / Fabrication
Jan 27, 2005 03:36 AM
ninjaman
Jul 18, 2001 09:55 AM
