Found a problem... Missing pins in block for exhaust manifold.
Old Jan 26, 2005 | 08:19 PM
rasinhell's Avatar
Default Found a problem... Missing pins in block for exhaust manifold.
Hey guys I have a Z6 laying around that i'm trying to put into an EG. It's missing a few parts so I have to swap what I can off the Y8 over to the Z6. I was taking off the exhaust manifold fromt he Y8 to put on the Z6 when I noticed that the Y8 block had 9 pins sticking out of the block to place the exhaust manifold on and the Z6 only had 7 and what appeared to be 2 holes where the pins would normally go.
I dont know if this is normal (probably not) or a real bad thing. Am I screwed and how did that come out in the first place and will it be hard to replace?
Old Jan 26, 2005 | 08:22 PM
ironcheftony's Avatar
its normal, the outer ones' use bolts instead of studs, u can just put bolts back in or put a stud back in , which u are referring to as a pin
Old Jan 26, 2005 | 08:24 PM
rasinhell's Avatar
Default Re: (ironcheftony)
Oh cool. Do you know what size bolt I should look for?
Old Jan 26, 2005 | 08:31 PM
Turbogixxer's Avatar
Default Re: (Special-Ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Special-Ed &raquo;</TD></TR><TR><TD CLASS="quote">Oh cool. Do you know what size bolt I should look for?</TD></TR></TABLE>
8mx1.25 and about 30mm
pinecone
Jun 25, 2006 07:26 AM
Turbo-Ekhatch
Jul 6, 2005 12:06 AM
crxgator
Dec 5, 2004 01:21 PM
AgentJam
Sep 10, 2004 05:15 PM
booscivic
Nov 27, 2003 03:14 PM
