Loose Steering on Hatch? HELP
Old Jan 26, 2005 | 07:45 PM
SlowSOHC-T's Avatar
Default Loose Steering on Hatch? HELP
I have a 95 DX hatch w/ a D15b. All stock except for Skunk2 Coilovers and sway bars all the way around. The car has no power steering, but the steering always feels EXTREMELY LOOSE. I mean to the point i don't like digging into turns much. Its real nice and stiff when im sitting still and driving slow. But once i get up into the rpms and mph it gets REALLY LOOSE. Its actually kinda scary. Is this common on the EG. Or should i buy a PS pump and put it on there? Will that help? What are my options? What else could it be? Any help would be grand. Thanks for all the help guys and gals.
-Andru
Old Jan 26, 2005 | 07:50 PM
hctjohnson's Avatar
Default Re: Loose Steering on Hatch? HELP (IWANTAHB)
It gets pretty loose especially @ higher mph, unfortunatlly this is common on these models. If you want to check jack your car up on stands grab the wheels and move them side to side(shake) if you get any freeplay you might have a bad tie-rod. Pm me with any questions
Old Jan 26, 2005 | 07:52 PM
GdmLaz's Avatar
make sure your tires are mounted correctly and ur alignment is good
Old Jan 26, 2005 | 07:55 PM
SlowSOHC-T's Avatar
alignment is good, as well as all the Tie rod ends have been replaced, at the time of the alignment. So what else could it be? Is it just something to get use too? When i drive my Chicks EK its like night and day, i can dig a turn as hard as i want and it feels the same, to where my car it wants to get all loose like a big body impala or something. LOL
-Andru
Old Jan 26, 2005 | 07:58 PM
Lmgrcivic's Avatar
Default Re: (IWANTAHB)
its more and likely your steering stabalizer alot of people forget about these, they look like a shock kinda there is two parts to it, it hooks to the rack and pinion.
Old Jan 26, 2005 | 08:02 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (Lmgrcivic)
Steering Column?
A smaller diameter steering wheel will also make it feel tighter.
Old Jan 26, 2005 | 08:04 PM
SlowSOHC-T's Avatar
i ordered a sparco flash 5. So maybe this is the cure.
But what about the steering stabalizer? What could of happend? Should i have it checked out?
-Andru
Old Jan 27, 2005 | 04:09 AM
Lmgrcivic's Avatar
they just wear out over time just like everything else on the cars how many miles you have on your car
Old Jan 27, 2005 | 07:46 AM
SlowSOHC-T's Avatar
140k on the body and around 40k on the motor
-Andru
jdm-allstarz
Jan 23, 2012 08:19 PM
ep3brandon
Aug 28, 2009 02:43 PM
shotime
Suspension & Brakes
Aug 8, 2009 10:24 AM
krysted9354
11
Nov 28, 2008 10:25 AM
suno
Suspension & Brakes
Mar 10, 2008 04:47 PM
