good flasher bad blinker
ok i have searched through the archives and have searched through recent topics but to no avail have i found my problem.
ok last night while out driving one minute my blinker worked, and then 2 minutes later they stopped working... all of them. the hazards still turn on but of course not the blinkers.
I went to the local parts store and picked up a new flasher and replaced it... nothing, went through both fuse panels and came up with zero blown fuses (checked numerous times).
I am basically stumped, they wont turn on period and its starting to really **** me off. i need to get this fixed cuz cops around here do not like it when a honda driver doesnt use their blinker.
I havent checked the wiring because basically im stumped on which ones are which. if it at all helps the car does have denji projectors but i dont think those wire into the corner lights.
something similiar happened to my sun roof. what the problem was is that the fuse wasnt tight in the socket. i had to bend the fuse a little bit so it has a better contact in the fuse block. It sounds like that may be the case with your car as well (but for blinker) HTH
eh9deux
Apr 19, 2010 02:30 PM
4speed
Aug 7, 2003 01:42 PM
