DX sway bar
Old Jan 26, 2005 | 05:51 PM
vegaskurt's Avatar
Default DX sway bar
Did some reading and realized that there are no mounts on the DX to fit the Si rear sway bar. Does anyone know of an after market one that will work, or is it eaiser to salvage parts off an Si?
Old Jan 26, 2005 | 06:07 PM
4drEF's Avatar
Keyboard Humorist
Default Re: DX sway bar (vegaskurt)
Rear or front?
Old Jan 26, 2005 | 06:08 PM
HatchBox's Avatar
Skoobie no more...
Default Re: DX sway bar (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">Did some reading and realized that there are no mounts on the DX to fit the Si rear sway bar. Does anyone know of an after market one that will work, or is it eaiser to salvage parts off an Si?</TD></TR></TABLE>
If my STD model has the holes your DX has them. They might be coverd by paint.
Just need to run a tap through them to clear the threads
Old Jan 26, 2005 | 06:21 PM
bagpipe goatee's Avatar
i haven't seen aftermarket ones, but someone must have them. myself, i salvaged the brackets off an si. you could even probably just weld some up if you have the skill
Old Feb 4, 2005 | 12:18 AM
93formula's Avatar
Default Re: (bagpipe goatee)
does anyone know if 88s have them? i kinda dont want to swap out the lower rear control arm, as i just bought a new set of struts and there 88 specific.
*Boostwerks*
Nov 15, 2006 09:22 PM
VeilSide_Mas
Aug 19, 2006 03:39 PM
MBDiagMan
Oct 27, 2004 11:12 AM
jtl
16
Apr 12, 2004 07:43 AM
TheShocker
Oct 16, 2001 10:39 AM
