LED FLashed 7 times, need something.
Old Jan 26, 2005 | 03:13 PM
jurenic's Avatar
Default LED FLashed 7 times, need something.
Ok, by looking in helms it says something about trottle positioning angle sensor. Now I checked it, and it's broken, I need anotherone. Anyone willing to sell me one?
Old Jan 26, 2005 | 03:16 PM
2.2XDreams's Avatar
Default Re: LED FLashed 7 times, need something. (jurenic)
you should be a little more specific, like what motor
Old Jan 26, 2005 | 03:19 PM
untitled's Avatar
Default Re: LED FLashed 7 times, need something. (2.2XDreams)
check classifeds...
Old Jan 26, 2005 | 04:07 PM
Widebody1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2XDreams &raquo;</TD></TR><TR><TD CLASS="quote">you should be a little more specific, like what motor</TD></TR></TABLE>
Well id say its in a 4th gen. so d-b series and last time i checked they are all the same....
Old Jan 26, 2005 | 04:13 PM
Mach69's Avatar
Default Re: LED FLashed 7 times, need something. (Widebody1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Widebody1 &raquo;</TD></TR><TR><TD CLASS="quote">
Well id say its in a 4th gen. so d-b series and last time i checked they are all the same....</TD></TR></TABLE>
I'm not sure about 4th gen d-b compatibility but 5th gen D16Z6 tps works on the a6 manifold and plugs up, but I wouldn't use the Z6 tps unless you want an idle at 4-5k, if not higher.
edit: USing the Z6 tps also instantly gives you a code 7.
Old Jan 26, 2005 | 06:05 PM
jurenic's Avatar
Default Re: LED FLashed 7 times, need something. (Mach69)
ups sorry, It's a D16A6. Does this explain also why my car SOMETIMES idles from 900-400 and back and forth?
Old Jan 26, 2005 | 07:05 PM
FalkenSiR's Avatar
Yep, same problem here. One of my main reasons for my upcoming mpfi swap
twiztid00002
Nov 15, 2007 09:00 AM
Ross 2.0
25
Dec 15, 2006 09:03 PM
budget
Jun 26, 2006 10:46 PM
vinuneuro
Jun 19, 2005 06:05 PM
digitalh3lix
Jan 1, 2005 04:57 PM
