HELP which clutch cable/adjusting nut to use ? B16 cable tranny
Old Jan 26, 2005 | 03:05 PM
efboy's Avatar
Default HELP which clutch cable/adjusting nut to use ? B16 cable tranny
i have a b16 cable tranny and currently where the clutch cable goes to the adjusting nut is <U>broken</U> and the piece is all gone..so i can't even shift cuz the clutch is not been pull due to the broken adjusting nut,is not hold on to anything.. for now i kinda use duct tape to hold it there, but it barely even holding the cable...i need to fix it ASAP
so if anybody can help, or guide me how to fix it.. and also need to know which part i need to use if i have to replace it ... thaknkx
Old Jan 26, 2005 | 11:15 PM
efboy's Avatar
Default Re: HELP which clutch cable/adjusting nut to use ? B16 cable tranny (efboy)
bumnpp pls help
Old Jan 27, 2005 | 01:15 AM
Ray-mond's Avatar
Just get one from any 88-91 honda civic or 90-93 acura integ just go to a local just yard
and look for an old honda or acura its just a plastic nut any ways they sell it to you for a buck your just give it to you or you can go to your local auto store a get a clutch cable nut or the whole cable with nut
good luck
Old Jan 27, 2005 | 06:16 AM
HOND PWR's Avatar
Default Re: HELP which clutch cable/adjusting nut to use ? B16 cable tranny (1Guamracer)
I have the whole cable with nut...$15 shipped.
Old Jan 27, 2005 | 06:36 PM
efboy's Avatar
Default Re: HELP which clutch cable/adjusting nut to use ? B16 cable tranny (HOND PWR)
actually the nut and the screw part is both fucked ..!! so should i just replace the whole thing include the cable? does if have to be for that b-series tranny or not ??
Old Jan 27, 2005 | 11:38 PM
Ray-mond's Avatar
I though they both would be and no any88-91 civic and 90-93 clutch cable will work
I really havent tried any others before they are not all the same length but it is ajustable nice car by the way
Old Jan 28, 2005 | 12:46 AM
efboy's Avatar
thnaks..it's is hard to fix ?? where should i start?
Old Jan 28, 2005 | 03:38 AM
Ray-mond's Avatar
Its actually really not hard just take it off from the tranny then work your way back to the fire wall that goes into the the car there is a plastic piece that looks kind of like a wing nut just turn it and pull it out from the engine bay there is also a little cable that goes from the fire wall to behind the clutch pedal just take it off this whole proses should take no more then 3-5 min If you find it hard to take it out from the fire wall
try pring on it with a screw driver from inside the engine bay make sure to twist that
wing nut first and good luck keep me post
b16_swap
Jul 23, 2008 10:07 AM
crxpwr1
Dec 28, 2006 04:56 PM
EKIM NART
Mar 12, 2006 06:06 PM
Dosvita
Mar 20, 2005 03:01 PM
