can i use a gsr intake manifold on ls motor
Old Jan 26, 2005 | 12:18 PM
STPREZ's Avatar
Default can i use a gsr intake manifold on ls motor
can i use a gsr intake manifold on ls motor and is it worth it will i see a difference
i can get 1 for $45
Old Jan 26, 2005 | 12:20 PM
Katman's Avatar
Default Re: can i use a gsr intake manifold on ls motor (STPREZ)
Negative.
The mounting holes on a GSR flange are a different pattern than LS flange bolt patterns.
You could use a Skunk2 LS I/M tho
Old Jan 26, 2005 | 01:52 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
yes, sure you can. this is a old pic from about 4 or 5 yrs ago (FFSquad was my fav)...anything is possible with a drill and a grinder and lots of free time on your hands. if you may ask "why?". it's because i love my oem parts and modified gsr intake manifolds (enlarged plenum volume and radiused inlets on the runner ends, good velocity). i noticed a difference cuz third gear actually broke the tires post spoolage of the turbo and it didn't with the stocker ls. doubt it would help on a otherwise stock ls cam and compression.
Modified by not so civic at 10:24 AM 1/27/2005
Old Jan 26, 2005 | 02:22 PM
Katman's Avatar
Default Re: can i use a gsr intake manifold on ls motor (not so civic)
nice work there
Old Jan 26, 2005 | 02:31 PM
mmuller's Avatar
Mad Scientist
good ****
not so civic; what did you do about the injector positioning and ports? did you rework the head to match the gsr IM?
Old Jan 27, 2005 | 08:55 AM
Default Re: can i use a gsr intake manifold on ls motor (mmuller)
yes i actually raised the intake port roof to take advantage of the spray angle better. yeah i didn't just slap it on. i took my time and took everything into account.
hey k@man thanks.
crxowner
Feb 22, 2006 12:12 PM
STPREZ
Jan 27, 2005 02:55 PM
STPREZ
Jan 26, 2005 12:25 PM
ziex73rew
Jul 27, 2004 02:59 AM
Bewkrazed
Sep 8, 2002 03:08 AM
