2000 Civic SI kickin my behind
Old Jan 26, 2005 | 11:23 AM
Chadmanwfo's Avatar
Default 2000 Civic SI kickin my behind
Okay, I have searched over and over and have had no luck. The B16A2 is not wnating to start. I have been over the car with a fine tooth comb and I am running out of things to check. The motor is fresh, have fuel(44#'s press.), Spark and compression. The engine tries to start but will not. If I unplug the injectors it will run and burn off the remaining fuel. The Firing Order, Injector Harness and Cam timing have been checked repeatedly. The injectors are functioning correctly but it appears as if the injector timing is off.
I have hoooked up the Snap-on Scanner no codes. I am really running out of things to check. I am sure I have left something out but any help would be greatly appreciated.
Thanks,
Chad
canned_civic00
Feb 16, 2011 06:24 PM
20sir00
65
Apr 7, 2010 03:25 PM
Devious951
19
Dec 1, 2008 01:15 PM
Chadmanwfo
20
Feb 1, 2005 04:55 PM
Turbolude
Dec 26, 2001 10:32 AM
