would this fit on a b16 in a del sol?
Old Jan 26, 2005 | 09:15 AM
jbell's Avatar
Default would this fit on a b16 in a del sol?
would either these fit?
its a b16a3 from a 94 sol in a s model 94 sol.
http://cgi.ebay.com/ebaymotors...&rd=1
Old Jan 26, 2005 | 09:18 AM
dunkd's Avatar
the one for the EF should fit... the one for the teg will be too short though
jbell's Avatar
Default Re: (dunkd)
too short in which direction?
Old Jan 26, 2005 | 09:43 AM
Del Sol SiR's Avatar
I thought the Type R one would just hang a little lower ? But it should still fit.
Old Jan 26, 2005 | 10:26 AM
jbell's Avatar
Default Re: (DelSolSiR)
bump for a definate answer.
Old Jan 26, 2005 | 10:28 AM
93_cxEG's Avatar
Default Re: (jbell)
hey bro it would fit just find but i think that on the s model for the sol ur gonna have to install the vtec and knock sensor wire harness...
Old Jan 26, 2005 | 10:30 AM
jerbear!'s Avatar
im sure either of them will bolt up, if it is able to bolt up with ur cat is the problem
Old Jan 26, 2005 | 10:31 AM
JDMisGOOD's Avatar
Default Re: (93_cxEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_cxEG &raquo;</TD></TR><TR><TD CLASS="quote">hey bro it would fit just find but i think that on the s model for the sol ur gonna have to install the vtec and knock sensor wire harness...</TD></TR></TABLE>
what are you talking about? anyways either will work just have to do some exhaust modifications!
Old Jan 26, 2005 | 10:36 AM
jbell's Avatar
Default Re: (JDMisGOOD)
**** **** ****. what do these exhaust modifications consist of? can i get away with a little flext tube or something inexpensive?
Old Jan 26, 2005 | 10:40 AM
one8toh8's Avatar
Default Re: would this fit on a b16 in a del sol? (jbell)
You said you have a b16 in the car now, if so what kind of header do you have, does that fit to your cat correctlly, if so as long as there are no mods done to the header on the car currentlly you will not have any problem with either one, there both the same size, so you need to find out if the header that is on the car is modified or if the cat is modified. Meaning if the header was not touched in any way you will not have any issues.
Old Jan 26, 2005 | 11:01 AM
jbell's Avatar
Default Re: would this fit on a b16 in a del sol? (one8toh8)
its not in the car yet.
its a stock b16.
its a stock s model cat mated up to a rs*r catback exhaust.
Old Jan 26, 2005 | 11:18 AM
one8toh8's Avatar
in that case the only problem you will have is with the header flange lining up with the cat flange just take to a mufflur shop and they should be able to cut the cat flange and reweld it to line up with the new header.
Old Jan 26, 2005 | 11:31 AM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one8toh8 &raquo;</TD></TR><TR><TD CLASS="quote">in that case the only problem you will have is with the header flange lining up with the cat flange just take to a mufflur shop and they should be able to cut the cat flange and reweld it to line up with the new header.</TD></TR></TABLE>
whats the difference?
my friend put a jdm b16 in his sol with a jasma header and it bolted right up.
Old Jan 26, 2005 | 03:29 PM
dunkd's Avatar
the teg header will not be long enough to connect to the sol cat.
for example when putting a GSR motor into a civic you need to use a b16 header, not the gsr, bc it will not bolt up
Old Jan 26, 2005 | 03:42 PM
jbell's Avatar
Default Re: (dunkd)
ok, so the type r will not fit.
what about the b16a header for the EF.
Old Jan 26, 2005 | 03:55 PM
JDMisGOOD's Avatar
Default Re: (jbell)
either will work...you just might have to add some pipe...no big deal!
Old Jan 26, 2005 | 07:18 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">either will work...you just might have to add some pipe...no big deal!</TD></TR></TABLE>
but why do that when you could just buy the right one.
yes - the EF one will fit. When doing a b16 swap into an EF u can use the stock header, and when doing a b16 swap into an EG you can use the stock header... therefore the answer is yes.
Old Jan 26, 2005 | 07:34 PM
jbell's Avatar
Default Re: (dunkd)
so its either...
or
http://www.streetimports.com/p...1.jpg
(image wont work, have to use a link)
however, look at the first pic... look where the o2 sensor is... will that **** up the reading, seeing as how its supposed to be near the cat?
Old Jan 26, 2005 | 08:02 PM
dunkd's Avatar
no, u would just have to extend the wire... but since u are buying a new one might as well buy the perfect one.
Old Jan 27, 2005 | 06:56 AM
jbell's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">no, u would just have to extend the wire... but since u are buying a new one might as well buy the perfect one. </TD></TR></TABLE>
the perfect one? whats that mean?
Old Jan 27, 2005 | 07:07 AM
eL's Avatar
eL
Maybe I dunno **** but on OBD1 cars, the O2 is by the cat isn't it?
Old Jan 27, 2005 | 09:43 AM
one8toh8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell &raquo;</TD></TR><TR><TD CLASS="quote">
my friend put a jdm b16 in his sol with a jasma header and it bolted right up. </TD></TR></TABLE>
Yo im just trying to help you out from my past experiences with both.
Old Jan 27, 2005 | 01:10 PM
jbell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one8toh8 &raquo;</TD></TR><TR><TD CLASS="quote">Yo im just trying to help you out from my past experiences with both.</TD></TR></TABLE>
why are you getting defensive. i was asking what the differnece in the flanges was.
Old Jan 27, 2005 | 01:37 PM
sir2sol's Avatar
either one will fit, I have a JDM ITR 4-2-1 header on my sol with a b16a swap and it fits like the stock manifold.
Old Jan 27, 2005 | 02:06 PM
jbell's Avatar
Default Re: would this fit on a b16 in a del sol? (sir2sol)
so what would you guys do:
this "jasma" header...
a jdm itr 4-1 painted black...
or a megan racing...
im afraid these will look nasty in a matter of a few days after they get hot.
