Oil Cooler install question
I've just pieced together an oil cooler kit.
How can I make the -10AN hose ends fit snugly with the -10AN stainless braided hose? It doesn't work very well just screwing them on.....
Like in this pic:
Modified by Pompiuses at 9:49 AM 1/28/2005
Like in this pic:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">um...j00 have it backwards...the hose goes into the red fitting.
Read up on AN fittings/hoses.</TD></TR></TABLE>
heh.... of course.... But should I put some grease on it or something also?
Of course what?
The hose doesn't thread into the fitting, the fitting splits the rubber hose and then tightens down on it when j00 screw it down on itself.
http://hydraulics.eaton.com/pr...n.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses »</TD></TR><TR><TD CLASS="quote">
no need to use grease -- just some black electrical tape to keep the braided metal sheath from fraying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delinquent »</TD></TR><TR><TD CLASS="quote">
So your saying that I should screw the hose end right on top of the tape?
</TD></TR></TABLE>So your saying that I should screw the hose end right on top of the tape?
Dude...READ UP ON IT! Go to the link I provided and download the installation instructions. That will show you the PROPER way of installing AN hose-ends, and it will show you that you're not even close to having it right.
Feel free to ignore my help and doing it your way, but have some kittylitter at the ready when you start it up, cause you'll have oil shooting everywhere.
*shrug*
*shrug*
did you read what el pollo diablo said? the fitting is configured backwards in the pic you posted -- it's the red end that attaches to the hose.
unscrew the the end of the red fitting -- it'll look like a nut with a hole through it -- slide that over the hose.
take the flared end of the 90 and insert it into the hose.
screw the nut back onto the 90, which will clamp down on the hose and hold it in place.
follow?
follow?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">Dude...READ UP ON IT! </TD></TR></TABLE>
Yeah I got it, the hose end is put on backwards in the picture.
follow?</TD></TR></TABLE>
That's a roger.....
Modified by Pompiuses at 6:28 PM 1/26/2005
That's a roger.....
That's a roger.....
Not exactly...j00 need to strip the braiding off the hose...otherwise it wont fit....again...go to the link.
the end
That's a roger.....
the end
the end</TD></TR></TABLE>
hmm...i've never had a problem making it fit with the braiding still on.
::shrugs::
::shrugs::
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">Oh my god, just stop now....</TD></TR></TABLE>
thats what im sayin!...... if you are having trouble with this then i should go ahead and tell you that you are gonna need to add extra oil once you get it all together or something not good will happen
I've got another question regarding the oil cooler install:
Is is safe to start the car "as normal" after the oil cooler is installed? There will be no oil in the cooler and the hoses. Is there something I should do make sure there's oil in the system before I start the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses »</TD></TR><TR><TD CLASS="quote">I've got another question regarding the oil cooler install:
If you have a thermostat then I don't think you can do anything about it. The oil won't start flowing through the system until it gets up to operating temp so I don't see anything negative from starting up normal. You might want to go ahead and add in an extra .5-1 quart of oil because when the T stat does open up it's going to bring it down though.
Somebody correct me if I'm wrong on any of this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero »</TD></TR><TR><TD CLASS="quote">You might want to go ahead and add in an extra .5-1 quart of oil because when the T stat does open up it's going to bring it down though.</TD></TR></TABLE>
That's a good idea
. But where does all the air in the hoses/cooler go? When the thermostat opens it'll get pushed into the engine, but then what?
That's a good idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richeybrooks »</TD></TR><TR><TD CLASS="quote"> thermostat opens?? there is a switch in the oil system?</TD></TR></TABLE>
I'm using a Mocal sandwich Adapter. Like this:
http://www.racerpartswholesale.com/mocal.htm
The thermostat will still allow a small amount of oil (usueually around %10 of flow) to pass by when the temps are low.
Just add a bit more oil (about 1/2l) and let the car get up to operating temps. Check oil again and top up as needed.
And you do NOT have to strip the steel braid off.
