How do I replace a speed sensor?
Hi! I just bought a 92 Civic that runs great, but the speedo doesn't work. I need to figure out how to replace the speed sensor. Can anyone give me some pointers? Thanks in advance.....
You might want to check if there is even a speedometer cable. My speedo didn't work and it turned out to be a missing speedometer cable. To remove the speed sensor just loosen the bolt (1) using a 10mm socket and turn the sensor in either direction while pulling up on it.
