99-00 si headunit
i got a 99-00 si headunit. anyone hooked up a system using the oem headunit.
put subs and a amp. i can do it if i cut and splice the wiring but theres no rca outputs on the back of the oem headunit anyone did this.
im selling a 99-00 ex headunit $50 no probs pm me. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 »</TD></TR><TR><TD CLASS="quote">i got a 99-00 si headunit. anyone hooked up a system using the oem headunit.
</TD></TR></TABLE> There are 3 things you can do, 1- get an amp with speaker level inputs, [ligh level] 2- you can get a LOC, [ high level ( speaker) to low level (RCA) converter] a little better but, but the same as the amp with the speaker level inputs. 3- take the OEM HU to a good car audio repair shop and have them install a set of preamp outputs, [female RCA pigtails] this is the best way, it will cost more, but it will be a much cleaner sig.
94
94
slateEKsi
May 26, 2010 07:39 PM
