my steering rack is bad has some play in it soo..
Old Jan 25, 2005 | 09:18 PM
4DRmafia's Avatar
Default my steering rack is bad has some play in it soo..
i hear the the hf steering rack from a crx is alot better than the si rack is that true ? and should stick with the si rack or the hf ?
Old Jan 25, 2005 | 09:38 PM
4DRmafia's Avatar
oh great now i founbd out that a STD is alot quicker than si/dx. i want something that will make me turn real good with out having to thurn the steering wheel 1/2 left or right for an exit.....so will a std/hf help out ?
Old Jan 25, 2005 | 09:48 PM
88crx-si's Avatar
Default Re: (SkipMic2006)
never heard about it but i'd like to know also...
BUMP
Old Jan 25, 2005 | 11:01 PM
rextec's Avatar
i know in the 1st gen crx's the hf has the quickest ratio rack but im not sure if it carries over....
Old Jan 25, 2005 | 11:08 PM
rsca_crx's Avatar
Default Re: (rextec)
chech the u-joint in the steering column 1st. i had a lot of play in that on a crx i had. a new one solved it. its an easy thing to check before you go and drop out the rack.
Old Jan 30, 2005 | 08:57 PM
4DRmafia's Avatar
the u joint at the end of the steering column ?
Old Jan 30, 2005 | 09:20 PM
Kwicko's Avatar
Down under the dash, on the floor, where the steering column connects to the steering rack, is the U-joint he's talking about. I think that's the one he's talking about.
As far as I've ever been able to find in any of my CRX factory service manuals, all '88-'91 CRXs got the exact same steering rack, at least in the US. The myth about the HF being a quicker rack is misleading; the HF rack IS a quicker one ON THE FIRST-GENERATION CRX ONLY. It's not that big a difference, either (3.6 turns lock-to-lock vs. 4.2). I put one in my '87 Si, but the biggest difference I notice is that it's harder to hold it on-center on the highway. It's more twitchy and nervous.
I can't say if the Civic STD got a different rack or not, but I'd bet it's the same.
Mike
GearSpeedKelvo
10
Feb 17, 2016 05:25 PM
iwantspeed
Apr 23, 2009 11:51 PM
Ldo
Mar 7, 2009 07:45 PM
EF_LSVtec
Jun 1, 2003 08:21 PM
ElementMotor
12
Mar 10, 2003 07:54 PM
