Brake Bleeding Advice and Help
Old Jan 25, 2005 | 08:49 PM
DIYaccord's Avatar
Default Brake Bleeding Advice and Help
I'm gonna tackle the first brake fluid change this car has ever seen in 200,000miles and need some tips.
It's my 1994 Accord LX with rear disc brakes.
Also, is there another fluid to change to for better performance? or is it like alot of honda items, where stock is good enough...
Thanks
N!(K
Old Jan 25, 2005 | 09:10 PM
momstaxi's Avatar
Default Re: Brake Bleeding Advice and Help (DIYaccord)
have a hand vaccum pump, it is alot easier. also, i know a company, i cant remember the brand, but someone makes blue colored brake fluid, that way you can easily tell when you have flushed all old fluid out of the lines. as far as tips you probably already know but, start at farthest wheel away from the master cylinder, ie: rr, lr, rf, lf. on the topic of brake fluid, i would say they are all about the same, i use the prestone stuff from autozone and it works fine for me.
Old Jan 26, 2005 | 06:52 AM
JimBlake's Avatar
What's better performance? Do you race? DOT4 has higher boiling points than DOT3. ATE Blue fluid has even higher boiling points, but it absorbs moisture faster so you gotta flush it more often. There's others out there, but under normal driving you aren't gonna tell the difference. Not unless your brakes get hot enough to boil the fluid.
Old Jan 26, 2005 | 10:32 AM
hondadude's Avatar
DOT 3 Brake fluid
Any more questions?
Old Jan 27, 2005 | 06:29 AM
DIYaccord's Avatar
Default Re: Brake Bleeding Advice and Help (hondadude)
Red X
I autoX...but mostly drive daily
Old Jan 27, 2005 | 07:56 AM
Slamaccord's Avatar
i used valvoline synthetic brake fluid. Worked just fine for me.
I acutally got it form autozone.
Old Jan 27, 2005 | 11:44 AM
SuperSlow's Avatar
DOT3s are all created equal. Daily driven usually won't need more. But if you feel like spending the money, get the fancy stuff.
DC4R27
Dec 2, 2009 10:03 AM
TheOne
Jul 20, 2003 03:28 PM
JMD
May 23, 2003 08:25 AM
Cosworth
24
May 22, 2002 07:49 AM
jdm92accord
Jan 30, 2002 09:29 AM
