main relay? no idea? car won't start-Please HeLp
car: 1990 civic dx hb-no mods
car has sat for a few months. just won't start. changed dizzy cause it had little to no spark-still nothing. fuel pump used to prime but it doesn't anymore. throwing codes 16 and 18 last time i checked. main relay maybe? any ideas helpful. i already checked all grounds and the usual(air, spark, fuel) it seems to ne more than one prob so that's why i think it may be the main. any help really appreciated. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo »</TD></TR><TR><TD CLASS="quote">16 is a fuel injector i dont see a code for 18</TD></TR></TABLE>
actually i think it's code 14-my bad. my friend has the car at his house and it's been over a week since we messed with it. i forgot and he's not too sure. but i think it's code 14
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo »</TD></TR><TR><TD CLASS="quote">no it is eacv not a iacv i am looking at my guide for info it is on the back of the manifold</TD></TR></TABLE>
its the same thing, people call it different things.
First off, if your fuel pump is not priming it more then likely is your fuel pump or main relay but but.... listen ... ok listening.... ( its about code 16 ) If you ever have a problem and your car will just crank ( won't turn over ), you sometimes will automatically throw a code 16, even though nothing is wrong with the fuel.
its the same thing, people call it different things.First off, if your fuel pump is not priming it more then likely is your fuel pump or main relay but but.... listen ... ok listening.... ( its about code 16 ) If you ever have a problem and your car will just crank ( won't turn over ), you sometimes will automatically throw a code 16, even though nothing is wrong with the fuel.
ok, it cranks just won't turn over. if you have ever compression checked your car that's what it sounds like. the main relay looks good, haven't tested it yet. i know the codes was 14 and 16 for sure, any more ideas?
ED3Sleeper
Oct 27, 2011 06:03 PM
{EF9} GrEaZe m0nKeY
Aug 12, 2009 09:26 PM
mike93eh
36
Dec 18, 2004 01:18 PM
allm0torGSR
Apr 30, 2004 05:10 PM
