Jackson Racing Supercharger
I am getting ready to purchase a RSX and I am looking into putting a Charger on it and I was wondering how hard it was to put on and if you have to tap the oil pan or is the jackson racing the charger where you put the oil in the charger and I also wanted to know what all you have to do to do this process and with the computer for the charger does it direct plug and play!! thanks
it isn't hard to install if you know what your doing. it took me about 4 hours to install the kit 1 hour to take off the im and 3 hours putting on the jrsc and pulleys. you don't have to tap anything it is just bolt on. there is a little black box j.r. gives you if you buy the street kit. if your going to buy the race kit u should definetly get the k-pro
whoa musta been imagining things. i swore i saw 05 mentioned somewhere hhahaha
if you're going to run it on street configuration. you're only going to net about 210-220whp. not wholy impressive. u need bigger injectors and custom ecu map to really get the big numbers.
