best B Series tranny?
Old Jan 25, 2005 | 07:03 PM
TrizzyDizzy's Avatar
Default best B Series tranny?
Hey guys, whats the best B-Series tranny? Im looking for drag specs, and dont tell me the Type-R Integra tranny, thats too much. I want something with an LSD already in it, strong enough, and good enough gearing for the 1/4 mile. Thanks in advance.
Old Jan 25, 2005 | 07:05 PM
Spade's Avatar
Default Re: best B Series tranny? (TrizzyDizzy)
the only b series tranny that comes with an LSD is the ITR
Old Jan 25, 2005 | 07:07 PM
HATCHingMN's Avatar
Default Re: best B Series tranny? (Spade)
ITR if you have money$$$
if not get youself a b16 tranny
Old Jan 25, 2005 | 07:12 PM
Default Re: best B Series tranny? (HATCHingMN)
I coulda swore that GSR (SIR-G) came with LSD. My friends old GSR supposedly did, but it wasnt ITR. Also, how much do ITR trannies usually run for?
Which B16 tranny? are they all the same?
Old Jan 25, 2005 | 07:21 PM
naman's Avatar
Was it not an option on Sir-G's in Japan?
HATCHingMN's Avatar
all b16 hydro are pretty much the same, and b16 is just like a ITR without LSD.
ITR---tranny should be around-$1000-up
Old Jan 25, 2005 | 07:23 PM
handa's Avatar
ITR>B16>GSR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">ITR---tranny should be around-$1000-up
Thats it?? well shiet, ill get that then. Im used to Subaru trannies being anywhere from $4000-$8000 for OEM transmissions!!
Old Jan 25, 2005 | 07:25 PM
JDMlyfestyle's Avatar
The JDM ITR 4.785 Final Drive Transmission is by far the best for performance
Old Jan 25, 2005 | 07:29 PM
Default Re: (JDMlyfestyle)
Ok so anyone know the best place to look up a ITR tranny? And i dont know too much just yet, would i need anything special, ECU wise for an ITR tranny?
Old Jan 25, 2005 | 07:31 PM
Spade's Avatar
Default Re: (TrizzyDizzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrizzyDizzy &raquo;</TD></TR><TR><TD CLASS="quote">Ok so anyone know the best place to look up a ITR tranny? And i dont know too much just yet, would i need anything special, ECU wise for an ITR tranny?</TD></TR></TABLE>
try all the swap shops for starters.
And no, you won't need anything special, just swap it and call it a day.
Old Jan 25, 2005 | 07:36 PM
Default Re: (Spade)
Sweet, well im just gonna give alotta people a call then. We'll see how it works, thanks for the quick response guys! Its almost like talking on AIM!
Old Jan 25, 2005 | 07:37 PM
beerbongskickass's Avatar
B16 + Quaife LSD, but if you do a lot of freeway driving GSR + Quaife LSD.
Old Jan 25, 2005 | 07:39 PM
Spade's Avatar
Default Re: (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">B16 + Quaife LSD, but if you do a lot of freeway driving GSR + Quaife LSD.</TD></TR></TABLE>
or just slow down.
Old Jan 25, 2005 | 07:52 PM
Eyes Only's Avatar
get either a lsd or a b16 tranny
Old Jan 25, 2005 | 07:56 PM
Why does it matter? Now are all B16 trannies the same? Thanks
Old Jan 25, 2005 | 08:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrizzyDizzy &raquo;</TD></TR><TR><TD CLASS="quote">Why does it matter? Now are all B16 trannies the same? Thanks</TD></TR></TABLE>
Why does what matter? I don't get what your asking...
Old Jan 25, 2005 | 08:05 PM
Default Re: (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">or just slow down.</TD></TR></TABLE>
Slowing down sucks.
Old Jan 25, 2005 | 08:06 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrizzyDizzy &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, whats the best B-Series tranny? Im looking for drag specs, and dont tell me the Type-R Integra tranny, thats too much. I want something with an LSD already in it, strong enough, and good enough gearing for the 1/4 mile. Thanks in advance.</TD></TR></TABLE>
US TYPE ARRRRRRRRRRRRRR with 4.7 final drive....
Default Re: best B Series tranny? (The Pastor)
Your not going to find a tranny with an LSD for cheap anyways...
Old Jan 25, 2005 | 08:07 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">The JDM ITR 4.785 Final Drive Transmission is by far the best for performance </TD></TR></TABLE>
so not true.....see my above post
4th and 5th in jdm tranny are same as us GSR meaning too long!!
Old Jan 25, 2005 | 08:09 PM
Like whats the difference in a B16 with a quaife, compared to a GSR with a quaife. Why would it matter about slowing down?
Ok, i see alot of people saying the ITR tranny is the only one with lsd, but all the shops say something about adding an lsd for $250 or something like that. now what LSD coems with that? is it oem? or is something aftermarket? Also, then how does that option compare with the ITR tranny and its LSD?
Old Jan 25, 2005 | 08:32 PM
B16 has shorter gearing than the GSR. Shorter gears make you accelerate faster, but your rpms will be really high on the freeway.
I am guessing they are talking about an OEM lsd if it's only $250. Hondas OEM lsd's are better than no lsd I guess, but if your turbo and making a lot of power it won't hold. If you go to the track a lot and launch high on slicks I would just save up for a quiafe lsd. Or maybe try out one of those OBX lsd's.
Old Jan 25, 2005 | 08:41 PM
WyteNyteGSR's Avatar
dude...LSD is Limited Slip Differential....its means when you have LSD the power is put down on both the front wheels equaly and they BOTH spin....if you dont have LSD only one tire with the less friction is going to spin and not the other tire...You can ad LSD to pretty much any tranny...... hopes that helps a lil bit
Old Jan 25, 2005 | 08:44 PM
Default Re: (WyteNyteGSR)
Thanks, i knew msot of that. Ok, ill buy a tranny without LSD, to save money, so i can add a stronger one later. So now all im worried about is the gearing and strength of the tranny. The b16 tranny has better gearing for the 1/4 mile than the gsr tranny? Thanks!
